Ruger 10/22
Just bought myself a Ruger 10/22 Takedown for my birthday.
Does anybody have one? Or any 10/22 for that matter? What do you think of them?
Congrats on the 10/22, it will last you years. I've had mine since the 80's. I just put a Hogue stock and shortened fluted bull barrel on it. Lots you can do with these rifles. Enjoy
I've had one for 14 years, has had thousands upon thousands upon thousands of rounds through it with minimal cleaning or lube. Accurate, dependable, and the triggers, for the most part, are okay but some replacement parts make a trigger job a lot more helpful. Only modifications I've made on mine is a Hogue overmold stock, trigger job, and I replaced the front sight with a fiber optic.
I think they started using plastic trigger group housings in 2005, which sucks (mostly because I'm traditional and prefer metal).
Overall, they're good rifles that can take about anything.
I finally bought one a couple weeks ago, but I have been selling them for seven years. In those seven years I have only had one come back with issues, which Ruger repaired immediately. They are great guns and the fact that you can customize them to however you like is great. Ever since the takedowns came out I can't keep them in stock. congrats on the new plinker
I have a couple. One is bone stock iron sights that I got for my son. I don't think he ever shot it. Oh well. Mine has a Leapers 3X12 scope and a hammer kit. I don't remember what kind. I think it was a pretty cheap one. It made the trigger much lighter but its not crisp. I've not been impressed by its accuracy, but I am not a great shot anyways. I probably should blame the scope since I've had some problems sighting it in.
Has anybody tried the new high cap Ruger magazines? I have a couple of 25 round plastic ones from before Ruger started selling them and they jam all the time.
Sounds like I don't like them, but I actually tell everybody who asks if they are getting one .22 that its the one to get.
10/22s are great. They are accurate for what they are, and i have had mine for almost 4 years now. I used to shoot it A LOT, and by that I mean over 1000 rounds a week, and it has preformed very well. Also, it's like barbie for men (like AR-15s). You can do anything to them that you want and use them for hunting as well as target shooting. Mine is very stock as it stands, with just a simmons 3-9x scope on it. I also added a bipod for prone position as well as to add more weight to it. I want to add a bull barrel in the future as well as a stock similar to the stock on an M40A3. just my two cents.
I grew up shooting a Marlin .22LR semi-auto, and really liked the ability to put multiple shots downrange without having to pull off the sights. Fast forward a few years, and it was time to get a .22 again. I decided on a 10/22 this time, since there's a lot you can do with them. I knew I wanted one with a bull barrel, but didn't like everything about Rugers target model. I decided to buy a basic model, and do work to it myself.
After shooting my stock gun for awhile, I knew it would have to be improved. In stock form, the sights were hard for me to use (got glasses since then), the weight of the gun didn't feel right, and the trigger was terrible. I did a lot of research, mostly at rimfirecentral, and started making some changes.
First thing these guns need is a decent scope. Open sights may work for some, but I really like to be able to see clearly what I'm putting my bullet into. I got a basic set of rings and a 3-9X scope at Cabela's for about $120, and mounted them. Much better.
Next problem was the trigger. It was so heavy and dead feeling, my finger would actually get tired after shooting for awhile (12 pound pull, maybe?). I tried the do-it-yourself stoning the trigger components method, with mixed results. The trigger was a little better, but still not smooth, nor light. I kept stoning it until it was fairly light (though rough), and left it at that.
Next improvement was to the stock. 10/22's have very short length of pull (at least for me), so I bought a 1" rubber butt pad to put on the stock. At the same time I got a polyurethane recoil buffer, which is supposed to help quiet the gun and beat it up less. The butt pad helped a lot, I must say. The buffer -- who knows.
Now the short, light barrel on the gun was bothering me. I did more research, and decided the Green Mountain 20" unfluted 0.920" barrel was what I wanted. I found one for about $100, and got ready to install it. To do this, you either need a new stock made for a bull barrel, or you can do what I did. Since I'd read that having something attached to the barrel messed up the harmonics, I removed the plastic band on the front, and cut the stock short so it wouldn't look funny. Next I started removing wood in the channel where the barrel goes, to make room for my much larger barrel. After a bit of work, I got it just right and mounted the barrel.
Things were starting to work much better now. With the LOP straightened out, and the new heavy barrel, the gun felt great at my shoulder, and stayed on target MUCH better. The trigger, though, wasn't giving me much love. After stoning away the case hardened material on the outside of the sear, friction started wearing into the softer metal underneath. I found this out while demonstrating gun safety to some non-shooting friends. "Always point your gun in a safe direction; always know what you might shoot. Keep the safety on and your finger off the trigger until ready to shoot. See - safety on, pull trigger - nothing happens. Now, when I push the safety off like BANG!"....
I now have a Power Custom adjustable trigger group in my gun, and it's wonderful. For a budget build, I think I have about the best setup you could get. The gun cost about $600 in it's present state, but I love it. The only addition I still plan in an adjustable stock from Fajen.
My gun:
I've had mine since 1983. I put a folding paratrooper stock on it shortly after getting it. It's a reliable, fun gun and it's very easy to accessorize.
I was given one for my 20th birthday more than 20 years ago. It is more accurate than I am, eats even the cheapest, nastiest ammo without issues, and is simply a pleasure to shoot and to own. Lots of accessories for it too, although mine is still totally stock.
I don't have a take down but I do have 2 SS models,one green laminate standard stock and one with a digi camo stock and my son has a SS green laminate international stock.Best .22s ever.
I have a regular 10/22 (not take down) and I love it, you can do so much with it, there are huge amounts of aftermarket parts for it. I put a bull barrel, 4-12x burris scope, and a boyds evolution stock....end result is a sweet gun!
have fun with it, I dont know what options you have stock wise for the 10/22, but I'm sure they are out there.
also, 25 round magazines are a lot of fun
They are great guns, haven't seen one of the take down models in person yet. A 10/22 and a fixed 4x power scope has taken a lot of squirrel, rabbits, and varmints out in the past.
Put your hand on your WALLET and visit rimfirecentral.com for everything .22 but especially 10/22 s.
The real danger is you will put $500-600 in making yours special..and that is fine..however when/if you sell it will bring less than sum of the parts..by far.
My beater 10/22 has the following;
1. Hogue overmolded stock
2. urethane bolt buffer
3. Volquartson target hammer { a $20 blem - TP is 26 oz]
4. Green Mountain bull barrel
5. After market bolt hold open/release
6. Firing pin pinned in and bolt jeweled by a RF whiz[CP or CJ]
7. 6-20X Simmons WTC
May not shoot it every time I go to the range but always take with me..and it is always fun to shoot.
Best.
PS: I was not kidding about keeping your hand on your wallet over at rimfirecentral.com - them folks can lead you astray fast but in the nicest ways.
Best.
I'd say let his wife (if married) hold his wallet while on rimfire central.....I didn't visit there till matter I built mine and now in thinking about another build...
I picked up one of the 25 round ruger mags recently. Works much better than those awful jamming plastic magazines. Had two of those, they went in the garbage.
Best.
This could have been my response
Ditto on the improvements, done all but #6, even put the same scope on mine
Great rifle
Would recommend the target hammer drop in as the stock trigger is so heavy it seems like the safety is on
+1 on that. The Ruger-made 25 rounders are wonderful.
I have 2 10/22s that were made in the early 90's. One is stainless, the other is blued. I'm considering getting one of the new "tactical" ones with a threaded muzzle (for the flash hider, which is actually useful for rabid animal defense in low light.)
I also might get a 1:9" twist barrel for my blued 10/22 to shoot Aguila SSS ammo in.
The 10/22 is a classic for a reason - reliable, cheap to shoot, and very accurate.
As far as small game and target practice goes, it's hard to beat.
I saw the take-down model at the gun shop, and it's pretty slick. Now you can snipe those varmints around the yard... but you have to do it from the roof of your house.
