Didn't wanna hi-jack the other dude's thread so I created my own.
I just don't understand why anyone would do steel liners rather than brass. Brass is the way to go. I love 1095 blades and I can easily maintain them. Non-stainless liners are a bear to keep from rusting, unlike the blade, IMO. I see no reason to use steel either. Not like we need the Pony Jack to baton through a tree. Plus I bet any perceived strength from having steel liners (vs brass) would be negligible.
I guess what I'm asking is why use steel rather than brass for liners on any traditional knife, GEC or otherwise?
Mineral oil and a bit of paper towel in between the liners. I use a bamboo meat scewer for heavier rust.
Regards
Robin
If I'm really cleaning a knife up (usually a new knife prior to use) I'll rinse it out really well with hot soapy water using a degreasing dishwashing liquid like Dawn. I work the blades open and closed and swish them around in the water to help clean out any gunk. Then I rinse with hot water and dry as well as I can with paper towels. I use a can of compressed air to blow out any remaining water. Then I spray with WD40 Silicone spray and work the blades some more.Do you guys use one of those air cans to blow out the liners or just run a thin piece of knapkin? I notice a little grit or sandy feeling when I open my blades.
Traditional. In the later part of the 1800's most factory produced pocket knives had steel liners. GEC makes all steel pocket knives (carbon steel blades, steel bolsters, pins and liners), just to be Traditional.
