Rust Problem
I made some blades using old buggy springs,(carbon steel) I heat treated the blades and then etched them in ferric chloride to obtain the old trade knife.Well I have put the knives together and now I'm dealing with rust mostly at the guard area as the guard is the same material,I have oiled repeatedly and it always returns. Is there anything I can do to minimize the RUST. Thanks for any help.
Rod
Did you etch before or after attaching the guardand was the guard soldered or epoxied on to seal it?
Bob
Your problem isn't rust but your ferric chloride. Etched steel must be thoroughly cleaned and neutralized.
Ok will try the windex, It shouldnt matter if I tried a rust remover at all should it?? As I was trying different things. Some of the metal is quite pitted and will require a little bit of scrubbing.
Rod
