Bill DeShivs
- Jun 6, 2000
I restore knives professionally.
Do not use steel wool and any kind of oil. This creates an abrasive slurry of iron oxide that will ruin any original finish that's left.
You can scrape off heavy rust with pieces of brass or copper. You'll have to keep filing sharp edges on the brass as it wears down.
Once all the heavy rust has been removed, use 0000 steel wool-dry. Don't scrub like you are mad at the knife-just lightly scrub at the rust. Change positions on the steel wool frequently, as it will contain iron oxide from the rust. You can shake it out or blow it out with compressed air.
After you have done all you can do with the steel wool, make sure all the steel fibers are removed from the knife.
Then, spray it with WD 40 and let it soak. Wipe dry. If a lot of rust comes off when you wipe. Soak/wipe again.
