Along with Bruises gloop(lanolin salve preparations), I've found a couple of coatings that are working pretty good depending on how permanent you want the coating to last.
#1
Perma Slik G
Original MIL SPEC Moly Film Dry lube finish to restore your USGI 20 round mags to like NEW condition. Color is a dull flat grey identical to NEW USGI 20 round mags. One can will refinish about 25 mags inside and out.
This item is ORM-D.We no longer use UPS--we ship these items via Fed Ex Ground. Perma Slik G Each: $16.00
http://www.georgiaprecision.com/cart/items/Magazineparts.htm
You can remove this product with steel wool and it will scrape off from usage unlike #2.
#2
Moly Resin will adhere to all metals including the following: aluminum, carbon steel, stainless steel, sandblasted and glass beaded metal, cast iron and aluminum, titanium, copper, silver solder, blued or parkerized finish, anodized, nickel and chrome plate, and many plastics, etc. Note: nickel and chrome plated surfaces should be abrasive blasted to allow the best adhesion of the Resin. For all metals, best overall results are achieved on freshly sandblasted surfaces. Moly Resin is available in the following ten standard colors but other colors may be special ordered. Special ordered colors are available in a minimum quantity of four quarts (one gallon).
Other Applications:
Moly Resin is currently being used as a coating by manufacturers of shooting glasses, caustic chemical valve and automotive parts manufacturers, gunsmith schools, as well as, for surgical tools. The applications are numerous and varied.
http://www.johnnorrellarms.com/molyresin_tips.asp
This is a seriously permanent hard finish
#1
Perma Slik G
#2
Other Applications:
