I really appreciate the support everyone, this has been a fun project for me. Bruce I had heard that in the past about the liners but it seems like there are a few opinions out there (As Always). I will be using liners with any natural materials from now on, thank you!
Mike I expect to get the Ironwood in the mail today. I am absolutely positive I will love it. How about I make a Kitchen Knife in the near future? If you are not familiar with Mike Davis work make sure you check it out. He is putting out some crazy kitchen knives!
Thanks brother.
I have almost finished everything up...
Here is what the scales look like after a 24hr epoxy cure, pretty nasty but I am pretty sure more glue is better than not enough.
I then hit the flat platen and even out the scales and make sure I have nice clean pins without any blowout or missing epoxy. Here you can see that EKG line that I wanted to match or compliment the SanMai pattern.
I than carefully take the scales down flush with the spine, and butt with the flat platen (On the finger section I use the 2" wheel, to keep the curves right.)
I then take the 10" wheel and start contouring the handle making the palm swell. I actually have a photo of one of Nick Wheelers handles above my grinder as an example of the contour I am trying to achieve.
I then put the knife in the knife vise and begin hand sanding with thin strips to round the corners and blocks to make sure everything remains flat, especially around the pins and spine. Moving up through 150 the 220 Grit. I then liberally apply 100% Tung Oil, I got this stuff from the local wood working store, it was not cheap but it finished extremely well.
After 10-15 minutes the Tung oil has time to soak in, I sand with the last grit I used (220) then move to 400 and apply another coat of Tung Oil and wait. and continue up to the final grit. This actually fills any small voids and polishes nicely. I took this handle up to 1000 Grit.
Mark, the spalted burl is beautiful, but as with any natural material it changes as you work with it. The EKG line is pretty much gone, but I am not upset at all on how it turned out. Looking at the overall package it all blends together perfectly IMO.
I have to put the final edge on it and decide what to do on the sheath today, I will post the final photos with sheath a little later.
