Would M390 be closer to S90V in edge retention and corrosion resistance (as opposed to S110V) ? What does the 110 , 90 and 30 mean in S110V , S90V and S30V ?
Would M390 and S90V be the same as of sharping go's ?
With S110V being the hardest to get a hair pooping edge .
M390 = what steel , made in USA ?
I'm hoping the success of the Blue Manix 2 in S110v convinces spyderco to make more knives in S110v. I really like the steel, however don't favor the rest of the knife. I'm not a huge fan of the FRN handles and lack of liners. I also feel the knife is a little too wide, and doesn't carry well. I'd give a finger for a BM 710 or Sebenza in S110v though.
It's about the same as a Military width wise so for me they carry the same other than the Manix 2 is a lot lighter.
The liners don't matter as it's more than strong enough to handle anything that a person should be doing with a 3.5" folder.
The blade will snap before those handles give out.....
Well, here is my take on the original question of M390 vs CPM S110V have quite a bit of experience with both steels in a variety of knives at different RC hardness ranges and geometries.
Both are excellent steels and very stain resistant.
Both steels are very picky about HT and the tempering processes to get them to that 61+ hardness range in production blades.
As far as straight edge retention goes it really isn't a contest as S110V will hold an edge longer than M390 and depending on RC hardness of both steels that gap can be very large as M390 tops out at 62 and S110V at 64......
Neither steel is chippy assuming a good HT.
The Carbide content percentage between the steels is very large and that's what gives S110V the advantage in edge retention combined with a higher obtainable RC hardness.
But even at the same RC hardness everything being equal they really aren't close...
Both are very fine grained.
S110V is a very complex steel that develops a very complex carbide especially in the higher RC ranges....
Thank you, I respect your testing over the years and your opinion of this M390 vs. S110V is very valuable. (My top 2 stainless steel)
I have heard that S110V HT can cause more warpage in blade blanks compare to , say S30V. Is that true?
MFL
