Everyone wants the answer to be steel and heat treatment but it's always more likely edge geometry, edge finish, blade geometry, thickness behind the edge and abrasive selection.I recent branched out into a lot more knives in super steels. Learnes I'm absolutely in love with M390, and just last week got a knife in S110V (Paramilitary 3). Week before I got an S90V ZT 0095 but didn't get around to fixing the edge up until last week.
I cut up a lot of cardboard at work. S90V held a surprisingly good edge, even the razor edge stayed, very uncharacteristic of of S__V steels in my experience. My Paramilitary did not fare nearly as well. First off, the edge seemed to have tooth that I could not sharpen out. The razor edge was gone after very little cutting, more like what I expect from S35VN and S30V.
S90V and S110V are supposed to be extremely similar steels, so any idea why they both held edges so wildly different? They were both sharpened to around the same angle with the same methods, but S90V took a hair whittling edge, and S110V only got to "pretty sharp" and the tooth never refined out?
The Burr is very misleading on S110V. It will raise very slightly, and raise before the edge is even close to done on the grit. Following the Burr would lead me to the toothy, not sharp edge I was getting. It's a very peculiar steel.OP... I dont know how you are sharpening, and in no way intend the following to assume you do not know what your are doing. Its just friendly advice.
Make sure you are raising a burr along the entire edge before switching to working the other side of the bevel. That burr needs to be raised on one side and then transferred to the other side. Once that occurs you can drop to your next lower grit transferring the burr back and forth. Never move to the next grit until you have gotten that burr along the entire edge on both sides. Once you have worked all the way up through your grits you need to strop to completely remove that burr. There are many techniques for stropping. This process is imperative for the high carbide, high wear resistant super steels. Also the more grit levels you use, the better.
The burr is much more difficult to see and even more difficult to feel on these high vanadium super steels, especially when compared to something like aus8 or 10-95, or 440a,b,c. I actually use a flashlight and shine the light at a flat angle from the spine towards the edge. If the burr is there you will see it. On the super steels it appears like a micro burr. The very edge of the edge will reflect the light. If this burr isnt totally removed, you will see the effects when you cut.
As for my own experience...
I have had great results with my S90V Military. I have used it a ton and it has held its working edge well. If hair whittling is = 100, shaving at the slightest touch = 98, shaving with effort = 95 then my definition of a working edge is 93-94. I have usually needed to touch up the edge on my spyderco fine stone. Only once I have needed to go to the medium stone and I always finish with a quick stropping and the edge is back to that 98 level sharpness. I have never let the edge get below a working edge and I have never reprofiled the entire bevel. That working edge seems to last FOREVER though.
That is interesting. In what ways were/are you disappointed?Old thread but my experience is similiar. Brand new para 3 in s90v is outstanding. Razor sharp and has held its factory edge. Got the native 5 in s110v expecting the same or better and have been disappointed so far. I have not attempted to reprofile the s110v but did just order a manix 2 in s110v and will report on the results. FYI... the s90v para 3 is sharper factory edge than my para 3 maxamet factory edge also.
After handling the para 3 in s90v and cutting a variety of household stuff (tape, cardboard, rope, ty wraps, marine caulk, etc) I was expecting the s110v to be similiar or better. I do have to say I have a more than a few knives (Im an amateur collector at best) and this para3 in s90v is by far the sharpest out of the box. I was pretty amazed by the s90v so maybe had unrealistic expectations of what s110v would do. Even still, it should have been on par with the s90v at a minimum.
