- Aug 21, 2014
that looks pretty nice after testing!
That can come off as a little rude.Your special HT might be very best but your knife design/making skill doesn't looks very well executed. I think it would be good for you to do HT service so the third party could also experience your special unorthodox HT.
you need to check out his YouTube channel. Lots of interesting stuff to see and learnYour special HT might be very best but your knife design/making skill doesn't looks very well executed. I think it would be good for you to do HT service so the third party could also experience your special unorthodox HT.
Be polite
Good eyes! Apexed at 600 grit diamond plate, deburred (a few swipes) with DMT E then EE.Bluntcut, what level of polish did you take the edge to? sorry if I missed it but could not find that. It looks like 400-600 level.
Agreed. My experiences are similar mostly to yours, except very keen edge would steer badly when chopping penetrate more than .75" into high density super hard woods such as katalox, african blackwood, lignum vitae, .. edge would buckle into big bent or half moon chip.I use to have a couple of heavy choppers, one made from 440C and one from ATS34, nether of which is ideal chopper steel. Back in the mid 90's choices were few. In any case, I used both to compare edge damage on hard woods. I ended up polishing the edges to 2000 grit and I was impressed at how much better the edge handled the chopping. Took far less damage. I knew it wood, but it was better than expected. I like 600 to 800 for large choppers that have tough steel. But if I ever own another weaker stainless chopper, I would likely go high on the polished edge. I wonder how much a difference that would make in your knife with s125
When HT6 is complete, I can try 1.2K diamond waterstone (which is equiv 3K diamond plate in term of polishing finish) on this 66.5rc s125v. At this point and given toughness didn't dropped too much and didn't gained more than 0.5rc, I project this chopper would overall out perform the result above. And would has crazy wear resistance even in chopping mode (harsh push-cut impact).
Brittleness can be cured by thicker edge bevel, low toughness can be cured by a wider blade. Now if you want a tougher blade, I suggest for your next chopper, you leave the first 3 1/2 inches from the hilt un-beveled. The 5-inch sweet spot at the front is all it needs.Preliminary test at conservative 20dps (instead of 18 dps) and at 70% chopping intensity. Will do full 18dps test video soon...
Under 30x loupe - Apex lost some carbides from chopping Argentine Lignum Vitae.
Hi-res image
I concur, added strength can mitigate brittleness. Though, only added toughness can cure insufficient toughness.Brittleness can be cured by thicker edge bevel, low toughness can be cured by a wider blade. Now if you want a tougher blade, I suggest for your next chopper, you leave the first 3 1/2 inches from the hilt un-beveled. The 5-inch sweet spot at the front is all it needs.
Sure, that is what often taken place when using conventional HT high carbide volume% under lateral flexing activities, such as chopping. In the video and closeup image of edge, this 66.5rc s125v subjected to a lot of lateral forces. S125V has very high carbide volume% - its spec: http://zknives.com/knives/steels/s125v.shtmlIm behind your edge holding and edge stability tests, some of the steels you are testing are designed for wear reduction and strength.
I feel like most high carbide/large carbide steels will fail under lateral flexing. Ive seen steels like D2, A2, O1, M2, fail due to breakage in Bladesports.
