Most logical things to consider would be that a thinner blade may chip more easily than thicker one and/or that there is a degree of randomness to these things. Others have reported minor chipping with S30V versions of both the Para and the Military, so even assuming thickness is a consideration, is not the only issue. My admitted limited understanding is, that the same carbides which provide wear resistance are what cause the chipping if some of them are right at the edge. If that's the case, it's not something the person grinding the blade can control.Recently, I was very surprised to find my Sage 1 chipped in two places after wittling a popsicle stick. Considering how soft the wood was, this left me quite puzzled and a bit disappointed. Immediately tried a similar stick with a D2 Para and had no problems. Don't know what to think...
Zip ties damage the edge? Never had that happen to me, even the crazy thick zip ties. Make sure it's a clean cut though, if you get a 30* edge in and start torquing it all over the place it might chip out a bit, but nothing major.
I have never had a zip tie chip a blade and would say that is not normal. But I have had S30V chip and I think on a new knife it is fairly common. I think it is because when the knife is sharpened at the factory they sometimes get a little overheated on the edge which can change the hardness and make it a little brittle. However, after a few sharpenings this more brittle steel is removed. Once it has been sharpened a few times in my experience any chipping will go away, unless it is abused.
I have lots of knives in VG10 and I have never seen chipping. I have a Spyderco kitchen knife and it sees lots of use from cutting up pineapples, veggies and other kitchen stuff. It has even seen bones when cutting up chicken or turkey - no chipping on anything.
It keeps an edge forever.
Selective hearing may be part of it.I could go along with that theory except for one big elephant that won't leave the living room>> Then why aren't all the other blade steels that Spyderco is using also chipping. I'm not hearing that about D-2, S90V, VG-10, M-4 or any of the other steels currently in use. Also I never heard that about it's CPM predecessor 440V (S60V).
Interesting hypothesis, except that I've never seen a burr on Spyderco's factory-new edges.There is a very good explanation for the chipping observed with factory new blades, and then no more problems after a good sharpening or two. S30V is very prone to forming a tenacious burr or wire edge, especially when using machinery to sharpen the blade, as I expect they do in the factory. If this burr is not removed at the factory, it will feel very sharp, but that burr will chip easily on relatively soft materials. A good sharpening or two will get rid of that burr.
Perhaps this does not explain all of the reported issues, but I suspect it explains a lot of them.
With all due respect "FlaMtnBkr" I don't think that's the problem. Because back when I first heard reports of S30V chipping about 3 to 4 years ago I was also hearing about another steel chipping and some of the guys at CPM were saying that S30V and a couple of other blade steels were very difficult to heat treat properly. I've heard that D-2 is so difficult is why many knife companies won't use it.
I also thought that it might have been bad batches but there are so many S30V blades that have failed people that I now just have to believe it has some very bad performance aspects to it.
Same here I've literally abused 3 of my VG-10 Spyders that I use for outdoor purposes and I've yet to have one chip. I never even ever had Spyderco's kitchen knife steel MBS-26 ever chip. And GOD Know's I've been very rough on my MBS-26 Spyders.
The only 2 user Spyders I had with S30V just didn't hold an edge as good as any of my 440V Spyders ever did either. And I could name off 10 more blade steels I've used of theirs that never chipped.
And I was surprised because of the good luck I had with 440V ( S30V's predecessor). It's either in the heat treating or other properties that need to be studied.
Pretty much any of the large, hard ( evil!) carbide containing steels are susceptible to chipping as shown in the picture with the factory type coarse grind. Those grinds feel very scary when we touch them, and do a great job cutting out of the boxbut the chips are the downside.
When taken up to a higher finish such as on the sharpmaker, or DMT, India stones those chips will pretty much stop, untill the edge gets too thin to support the load, or if misused by twisting out of cuts, or some such other contributor.
