Sure
We start by cleaning them with acetone - double wrap tightly in high temp stainless foil with a bit of paper in the envelope to eat up O2 before it gets to the blades. We cook them 30 minutes at 1950 - plate quench between thick aluminum plates with the foil still on. When hand cool, remove from foil and freeze - we use liquid nitrogen - dry ice and acetone works fine - overnight. Next day, we double temper according to desired hardness - normally 400 degrees for RHC 60-61 - 2 hours each temper. Then we rockwell each blade - retemper if necessary to go a bit softer and we're done.
Pretty good results
Note, if there are obvious stress points, burrs etc, we'd do a flash temper at 350 for 1hr before cryo - but we prefer to go straight to cryo from quench.
Rob!
