- Apr 7, 2002
Razorback - Knives said:Ron told me he has broken hollow grind knives in the field.
With the type of grinds and edges you prefer, you be best suited to use something that contains a razor blade.
Sounds like your line up is on the money. Even though I prefer a convex grind, I do upon request, hollow grind and flat grind. I personally like a convex better and if I need a slicer/cutter I'll go with thinner steel. Sorry for the hijack Merlin.Cliff Stamp said:I like full hollows on high alloy very hard steels for pure cutting knives, flat for general utility and full convex for heavy choppers (parang class) in low alloy steels maximized for toughness.
-Cliff
Razorback - Knives said:... though I prefer a convex grind..
STR said:I also believe that you can grind D2 thinner and still have a knife as tough as another steel ground thicker.
Bob Dozier's grinds prove just how thin you can make the D2 steel and get away with it.
Artfully Martial said:I hear about brittleness of D2 ...
Tom Krein said:S30V prices have gone up markedly so it will be more expensive.
This implies it is tougher which is rare as D2 is one of the more brittle tool steels and similar to the high carbon stainless steels.
STR said:This coming from the guy that broke a D2 point on a Dozier knife in one of his tests and then argued with me repeatedly in denial when I pointed out that D2 was known for being a brittle steel.
But it is wear resistant and capable of being ground very thin so it has some toughness.
STR said:I know of guys that have broken D2 as well as S30V blades by dropping them Cliff.
I couldn't help but make note of your now saying D2 is brittle when before oh no, not brittle.
You would be pushing the limits of the steel to be that thin on an S30V blade and even other steels too.
...what happens if you make an M2 or D2 blade and leave it thick?
STR said:I imagine that in a thicker blade D2 would suffice for most people except for guys like Cliff...
As for S30v vs D2 in regards to toughness, I have seen much worse behavior from S30V than D2 but right now I am not convinced that this is the true limit of the steel as it is just a heat treat issue.
I wholeheartedly agree.............it's a kickass steel that screams beat me, beat me and beat me some more.STR said:5160 is a tough ass steel IMO.
