My Lone Wolf T1 Harsey's S30V blade held up much better than any Benchmade's S30V knife I have ever owned.
There is a significant difference between a small folding knife and a large fixed blade. As we blur the differences, with tough folders, we blur our understanding of what common sense suggests.
Very true, do you have one? I like mine. Picked mine up for 120 before I owned my store.
Are you saying that hard-use folders should not be used hard? There are some really beefy folders that look to be designed for such hard use tasks that a fixed blade is traditionally used for.
I'm certainly not going to let this incident put me off of the steel or the maker.
If you had two blades of the same steel, same HT and same profile and thickness, one mounted as a fixed blade, and one mounted as a folder, shouldn't the only difference be in strength of the blade/handle join?
Thought this photo might be of interest.
This Benchmade / Ritter RSKMK1 belongs to a friend of mine. He does a great deal of wilderness travel all over the world and while he himself is not particularly hard on tools he is someone who really needs gear that is 100% reliable. Now you can take it any way you like, but the pictured knife is the replacement which he was sent after the first Ritter be had failed in exactly the same manner.
The first chipped out while he was trimming up a thumb thick sapling in Borneo. After that failure he didn't feel like taking the replacement anywhere that he might want to rely on it, so only used it while at home. This second blade chipped while carving the notch in a finger thick red cedar hand drill hearth board.
Neither cutting job was something that I would have considered outside the scope of a knife like this. In fact, I wouldn't have thought twice about using my own RSKMK1 for either job if it was the knife I had to hand.
Maybe my friend has a peculiar way of using a knife which puts undue stress on this part of the blade, maybe he has just been really unlucky and had two successive blades that slipped through quality control, or maybe the steel/cross section combination isn't quite up to the job?Maybe a combination.
Anyone else had anything like this happen with a Ritter, or any other S30V Benchmades?
I have ground the chip out now and maybe the thickened up edge will fix it for the future. My friend said he didn't want another replacement and isn't even all that bothered if he doesn't get this one back. I can kinda see where he is coming from. Personally I don't plan on leaving my own Ritter at home when I go on expeditions, but I reckon it is going to take a while for me to look at that little skinny edge again without a few misgivings.![]()
H1 is pretty tough. Then again it's not stainless...it's stain proof.
I was just informed of this thread and would like to reiterate that Aeromedix and Benchmade stand behind Dougs RSK-Mk1 knives with a lifetime warranty. We certainly find it odd that apparently this knife reportedly failed in the same manner as an earlier one and not under use wed normally consider abuse. In any case, we would prefer to have had the knife back in its original damaged condition and either replaced it or refunded the customers money, since we cannot analyze a failure otherwise. They are rare enough that we are always curious to get to the bottom of it. The RSK Mk1 is a production knife, so occasionally things slip through even Benchmades generally superior quality process, but this is extremely odd. Clearly, Doug wouldnt be putting his name on a knife that wasnt up to the job he designed it for and clearly if we had many failures such as this, wed not still be selling them. While designed as a slicer in accordance with Dougs philosophy, it isnt a sharpened pry bar, I know he, as well as many of our customers, certainly work them very hard and Doug has often explained how he abuses and tests them just to find out what they will take.
If any customer ever has a problem with one of Dougs knives that we have sold, we hope you will contact us and allow Aeromedix and Benchmade to provide the first class customer service upon which Doug, Brent Blue and Les deAsis have built their businesses.
Eric
