s30v vs. 154cm vs. ZDP189 vs. INFI
I found some microchips in my Sebenza, done mostly while hacking some small limbs off of a branch. I've been a long time s30v fan and figured I'd bang around with a few other knives to see what's up.
First off, all knives except for the mini-grip have been resharpened on a Sharpmaker and stroped on a Hand America strop pad with chromium oxide. The chips are out of the Sebenza (ther were quite small) and the Busse was reprofiled on the Sharpmaker.
Here's what they did: And the pics are here: http://echoesphotographic.zenfolio.com/p825732424
Password is "bladeforums"
  • strip small limbs (1/4") off of a branch.
  • Took each limb and cut off 5 separate chunks using a rubber mallet using a piece of cedar decking as a cutting board.
  • Then I battoned each knife into the end of said cedar decking. Again, all of course did perfectly.
  • Sliced newsprint to test edge retention, about an eight inch cut with each knife.
  • Took each branch and made 25 cuts per knife, cutting the tip off the branch each time.
  • With the full belly of each knife laying parallel on the cedar I gave each knife 3 good whacks.
  • Then it was 10 cuts shaving the corners off of cardboard.
  • Took each knife and battoned it into the decking parallel to the grain, each knife was hit 3 times with the rubber mallet on the spine.
  • Shaved 10 long strips of cardboard.
  • Sliced newsprint one last time.
Each knife feels great in the hand, formed like they were meant to be there. The mini grip did feel small, but choking up actually made it feel good. The Busse fits the hand the best, the Caly 3 second, the Sebbie third. This is splitting hairs here. The Caly's carbon scales do have a little grip to them but I don't know if that would hold true in the wet.
Before each slicing test of newsprint and carboard, each blade was cleaned and wiped free with WD40.
I didn't try to be gentle with the mallet, I wanted something to chip. For some odd reason, I wanted my Sebbie to chip again and be the worst of the bunch. It wasn't. There wasn't really a clear loser, the Busse did well but it's thickness made cutting the cardboard a little harder but they all did the simple tasks at hand very well.
There was a clear winner though, the Caly 3. If you want a well made slicer who's sharpness ability will be if not already, legendary, this is the knife.
What does this simple test prove? Well, not much really. It wasn't an abusive test, nor was there enough cuts of anything made to prove anything although the Sebenza cut just as much today as it did before I noticed it being chipped. The ZDP was suprisingly strong. I expected this steel with such a high RC to chip but it did great. The Busse, well I just wanted to beat the living crap out of this knife. It's something to drink the koolaid of that brand and just hold the thing and think it'll go through a brick wall. The mini-grip is too small and needs to be replaced with a full size WilkinsGrip. The Sebbie? Well, after I brought everything inside, touched them all up on the sharpmaker and the strop, this one went in my pocket and we left for the day.
I did learn one thing I think. These new steels all should be touched up from the get go. The mini-grip is the only one that came out with visible edge damage and it's the only one that still had it's factory edge.
Take it for whatever it's worth. Maybe something else will happen later down the road and I'll add to this thread.
I dont recommend chopping with really hard stainless steels for that reason. Those fun, but usually unnessasary type of tasks would be better handled with a good carbon/ tool type steel instead. enjoy.
For what reason? All but one of the knives cam out undamaged, including the one non-stainless knife.
Agreed - that's just knife abuse in my opinion. Those steels are superb for cutting and slicing; if you want a hatchet, go buy a frickin' hatchet.
Batoning with a folder is a good way to break it. Though you didn't do it that much it still puts serious stress on the lock.
I need a password to look at your link.. Whats ur password?
BTW.. When I had regular sebbie.. It chipped alot too.. not micro chips either but... Actual chips...
the password is "bladeforums"
Knife abuse? I used a rubber mallet. If that made any of those knives fail, they're not worth a spot on the 5 dollar rack at Cabela's.
When the Ritter Grip was tested in a magazine, they use wood to test battoning. It happens.
And Donny, if it was unnecessary then I don't think Doug Ritter would have given a folder a 'survival' tag.
Its like useing my car to perform truck tasks, ill get away with it for a while, but sooner or later i will be reminded its really a car, no matter what my skill level is. As far as mr ritter is concerned, the ethics involved in refering to a folder i would like to sell as a "survival tool" is something i wouldnt do either reguardless of my skill.
Agree. Batoning a folder designed for slicing is ill advised.
Yes, you can do it, but not always with impunity.
This is not a realistic performance expectation for this type of knife.
My interest is primarily in the GW and Sebenza, as those are two knives I commonly carry.
I had some very light initial chipping in the S30V Sebenza that I EDC, but it did not re-present after I reprofiled the blade.
Rather than batoning (which is not something I would be likely to do with a folder, and not even going to bother commenting on the "abuse" B/S that's become fashionable of late) I would find a relatively hard medium to chop on... like a well cured piece of hard wood. That should illuminate the chipping issues.
My experience with CRK S30V vs. INFI is that the S30V holds an edge a bit longer, the INFI is a little easier to strop back up, the INFI is much tougher, and the INFI is a little less stain resistant. So both steels are pretty well suited to their respective tasks.
It would be interesting to machine a spare 'Benza blade out of an INFI donor, and I may get to that point. But... I think for my purposes, the S30V works pretty darn well for a folder - even in the Large 'Benza size.
Did you guys read my first post? It's not about batoning a folder or not. It's about how the different steels seemed to react.
There is a "new age" of what is concidered to be the "new knife performance exspectations", reguardless of reasonability or safety of the technique thats being discussed, combine that with over the top marketing by individuals who claim they can survive with a razor blade, and So by nature comes the back lash of a more rational sort, who cannot allways interpet the intentions of some posts as easily as others, and that where you came in. Welcome to the belly of the blade forums beast. just kidding
well said.
Donny, you need to join the pirates.
Again, that has what to do with the thread?
Actually, my post was trying to figure out why s30v had a bad rap. My Sebbie chipped, I thought maybe the bad rap was deserved. So I gave 'er and a few other knives a little boy scout test. Turns out, they're all pretty equal in what could be a standard days duties of folders...
Cutting cardboard.
Mr Clean , nice comparison , any chance you can use a mic , and measure the edge thickness of each ?
Be much appreciated.
Taken from manufacturers websites and forum info:
Caly 3 - .125"
Sebenza - .125"
Busse - .140"
Mini Grip - .100"
Which surprises me, they certainly don't feel that close in thickness. I think what makes the Caly such an excellent slicer is that the blade is taller and flat ground, giving it less shoulder behind the edge. I wish I owned a mic so I could mic behind the edge.
Mr Clean,
I think the comparison and review was nicely done. Thanks for that and the pics. I personally don't see a need with battoning folders, but I also don't see that much of an issue with it either. Please continue to add to this thread if you do more comparisons.
This is not too much load to see difference. But even this gave some idea what each steel can offer. I think you need to five-ten times more.
Thanks, Vassili.
