So what steel would be tougher?Cliff Stamp said:For most cutting yes, ropes, cardboard, foods and such. On some really hard work like digging, a slightly tougher steel can be better for edge retention as it can prevent chipping.
-Cliff
bzzhewt said:Am I close?
bzzhewt,bzzhewt said:I wish they made a small pocket folder in 52100.
In regards to edge retention, this is dependent on pretty much all the various steel properties, strength, toughness, ductility, wear resistance, and corrosion resistance. Which ones are important depends on what is being cut and how.
Strength keeps the edge from rolling/deforming, ductility and toughness keeps the edge from cracking, wear resistance keeps metal from being scraped off the edge and corrosion resistance prevents the edge from being consumed by oxidization.
Cliff said:
To give some credit :
Alvin argued for hardness in edge retention and fine grain structure in opposite to the edge holding = wear resistance theory that is most popular, even today. Mike Swaim and Alvin's other field testors evaluated his claims vs many knives including Bos hardened ATS-34.
Later I discussed this with Wilson who had reached a similar conclusion in that unless the hardness is high enough, the wear resistance is of little value because if the edge is too weak and loses alignment it will be dull even if it isn't worn at all. He tested some extreme steels (S90V) at really low HRC's and noted the performance bottomed out, as the edge just rolled.
Busse also developed his ideas about edge retention for a radically different class of knives than Alvin and Phil, and he concluded that toughness was critical as you have to prevent micro-cracking. Busse and Glesser were the first two in the industry I heard talk about examining edges under magnification to study performance. J.J. did similar in regards to developing his ideas on sharpening.
Carl64 said:Once design and materials are chosen, our biggest question is hardening and tempering."
Second, even early experience told me that harder blades just plain worked better. I throught sharpening was a pain in the butt until I got some better knives, and they stayed sharp longer too. Harder blades seemed to make everything better.
The problem with poorly-performing blades is almost always a burred and deformed edge after short use much more so than simple wearing down.
This brings us to my next goal, which would be stating exactly what level of hardness would be the minimum reasonable rating for a specific level of wear resistance.
Manufacturers seem happy to rely on it ...
But deformed edges would quickly show their drop in cutting ability.
I agree but I have not experienced such issues that I know of.
