- Sep 6, 2007
If you really want a steel than can get sharper than both S30V and D2, try ELMAX or go with pure Carbon --if you don't care about corrosion resistance.
I've been doing research and I'm getting mixed reviews about s30v and D2 steels. can anyone ell me which steel takes the sharper edge, I don't care about how hard they are to sharpen or corrosion resistance, I just want to know which one takes the better edge.
Thanks, dantheman4114
I have my Benchmade Kulgera sharpened to a 20* per side 40* inclusive. On second thought thats most likely what I'll be putting on the 940.
In my experience, the edge on a D2 blade lasts longer. S30V takes a wicked edge (as does D2, perhaps even better) but it wears off relatively fast.
In my case, with an RJ Martin "Blackbird" chopping into Maple, S30V does way more than wear faster: It fold over into a micro-wire edge in less than 15 chops at 30+ degrees inclusive. You can see the wire edge exactly where the blade hit, and no wire edge where I didn't hit... And I am careful about exterminating wire edges beforehand. It may even happen on the first few hits...
A 1985 Lile "Mission" in D-2, by contrast, will hold up perfectly in a hundred chops at 20 degrees inclusive.
No comparison at all, the D-2 (or 440C, since Lile doesn't mark them) is way superior, the S30V being so bad it actually ruins an otherwise fine knife.
And RJ Martin is a stickler for heat-treating to specs down the last detail... I general, based on my S30V experience, I would always avoid any CPM steel.
Gaston
