S30V vs S60V
Dick, As far as my experience goes everything you were shooting for on 30V was obtained. I remember some of our conversations on what a dream steel for knife makers would look like. I can only conclude that the problems here are not due to the steel. Here is what I have settled on for 30V heat treat. Preheat at 1550, ramp to 2040, takes about 15 min to get there with my furnace. Hold 40min and quench in front of a fan. As soon as it comes to room temp direct into LN2 for 2 hours min. Longer does not seem to hurt. I have left as long as 2 days. 2 tempers at 400. This usally gives me RC 60, measured on a old Wilson tester but with a test block furnished by Rockwell themselves. I grind about 30% of the blade "after" heat treat, finish the blade and polish and then re-temper as a last step to remove any residual stress. I am carefull about de-carb in the furnace and use Norton RG abrasive belts for the rough work and SC belts for the final finish. I sharpen with SC abrasives to form the initial edge and touch up as needed with diamond stones. As I stated before my flexible blades will plastic deform a lot before breakage. I can get some very fine chipping whittling hard wood if I twist the blade out of the work. I can do the same thing with 154CM and D2 and 90V at the same hardness. I feel like 30V is a realitivley tough steel, only betterd by 10V.. Maybe this will serve as a baseline for heat treat of this grade....Phil
Phil Wilson said:
Paul, I made a lot of knives out of S60V and eventually worked the hardness up to about RC 58 and settled for that as a good compromise between ductility and strength.
I think a lot of the problem with steel perceptions is that there is a serious problem in general with admitting that not every steel is suitable for every task in the industry and thus makers should have a family of steels to work from unless they only make one type of pattern.
After looking at the chart for S60V I would have liked to see it from 2050 F with salt/oil + cryo to 60+ HRC in a light use cutting knife with the edge ground really thin and acute. But it started being used in tacticals and gained a reputation for chipping.
-Cliff
Cliff, I pretty much went to S90v when it came out, invested in a lot of steel and kind of lost intrest in 60V. I think it had more potential but there is only so much time. 90v does everything 60v did and then some. I also invested in a lot of 154Cm and now we have CPM 154. I have tried and like everything about it but for the right application 154 CM is still a great steel. I am also working with some ZDP 189 and like it as well. It is a little overwelming. I think a guy has to settle on a small family of steels, figure them out and like you say pick the right one for the application. Phil
Cliff Stamp said:
I have seen a few people propose this arguement, however isn't the machinability of S30V superior to D2/M2? In regards to heat treatment, this is always a possible problem, but S30V was promoted as being easier to heat treat than 440C so it is hard to see why heat treatment would be more of a problem for S30V than other cutlery stainless grades.
-Cliff
If you look at machining and grinding as two different operations. S30V may offer more resistance to grinding than will D2 or M2 since it has a higher carbide volume than does M2 and much harder carbides at similar volume to D2. As far as machining is concerned the reduction in carbide size from roughly 30-50 microns to 2-4 microns make the material easier to machine since the tool can scoop out the smaller carbides instead of trying to cut the larger carbides in half which will dull the tool edge.
Also keep in mind that the machining complaints were with respect to high vanadium grades like S90V and 10V. Before you comment on what the material was supposed to be you should check on what the real design criteria was for the alloy. Also to comment on your next post I never nor did anyone else at Crucilbe say that S30V was the only alloy which should be used for kinves. It was designed based on some very specific requests from people like Phil Wilson. It was never intended to replace alloys like 1095 or A8 (infi). It was intended as a high performance stainless knife steel.
RTB
RTB
I'm just checking - did you just say A8 (Crucible A8?) is INFI?
intersting stuff read here
so can some one tell me why crucible told me that cpms125v is not out of R&D yet
are they reformulating it or something i was realy looking to try it out on a folder i have planed
i also had cpm154 ,cpm3v and 10v shiped in for me to test out . i cant wait to start on the 10v project i have
butch
I do not believe Crucible ever sold any A8 to be used for Infi but I do believe that Bohler has sold their modification of A8 (chipper kinfe) to Bussi.
Yes, I can understand that, for a knifemaker as well you also have to make knives to sell so you can't afford the time of course to examine every single alloy in detail. I just think that approach to S60V which a lot of people ended up taking by dropping the hardness down to 55 HRC to make it suitable for tacticals and hard use in general is problematic and comes from the wrong viewpoint of trying to make a steel do something which is far outside its optimal range.
Even though the wear resistance is still high at low hardness, of what value is this in knife edges about 0.3-0.5 micron's wide when sharp, if it deflects and rolls even to a micron or so it makes a massive change in sharpness with little to no wear taking place at all, so hardness is really important, which you know already, but a lot of people don't share that viewpoint and those knives were made and a lot of users complained when all of a sudden they had "super steels" which were rolling and denting very easily.
Yes, not many people in the knife industry make those distinctions, Mission does as Beta-Ti is ground poorly in general but machines easily, on a belt sander it heats up fast but you can file it rapidly. Crucible only discusses machinability in the spec sheets and promotes it as high for the reason you noted which then tends to give the wrong impression if the grindability is significantly lower.
Before you comment on what the material was supposed to be ...
Crucible promoted it broad spectrum, the data sheet specifically states its toughness makes it "especially good for bigger blades", so this does compete with INFI and other steels as that is what they are used for, and it is used for exactly those types of blades. Now obviously Crucible has no responsibility for what makers do with the steel, but where is the information from Crucible saying it should not be used for those applications and is sub-optimal, if anything, the data sheet promotes it.
In general though I was speaking more of the common perception as steels can be judged harshly for properties which don't matter in many applications. I have lots of knives which have very low charpy values (M2 at 65 HRC), but if I am only cutting with them and not subjecting them to impacts of what use is a high impact value, I would rather have a higher tensile/compressional/torsional yield/ultimate fail points, which I do have on those knives and they work very well.
What I would like to see more of is makers like Wilson who has a family of steels to work from as all are quality for various applications and not every blade for every person needs to be the same, and not ever steel is a "quality" choice for every blade, but just do some reading and you will find that use of the label which is itself misleading, similar to saying something has good "edge retention", this depends on what is being cut and how.
From a materials perspective, how do you feel about the japanese trend away from vanadium, and alloys like ZDP-189. The high vanadium alloys have been critized harshly by a japanese metallurgist on the forums. Have you contrasted the high vanadium approach with theirs and found it to be superior? Have you examined the work of Roman Landes who has harsly critized the use of steels like S60V for knives due to primary carbides interfering with sharpness and edge retention.
-Cliff
S125V was never out as a commercial material. I believe pieces made it to three knife makers Phil Wilson being one. Last I spoke to him he had made one knife out of it and had no intention of ever doing it again due to the problems he had grinding it.
You will have to check with someone at Crucible to see if they intend to ever do anything with the grade. I doubt they will as a monolithic alloy. THey may use it on hip clad parts.
Farid advertizes S125V as one of the steels he uses, have never used any of his knives, but he uses a lot of very high alloy steels like T1 for example.
-Cliff
spyderco has a sprint run of natives planed in cpms125v
see its funny because one time i was talking to my rep at crucible and he got me heat treat info and sizes i could buy then a few weeks later when i went to order i was told it is not in the system so i thought
A they are just changing the mix a little
B didnt want someone they didnt know first hand working with it and maybe messing up the heat treat and giving a bad name to the steel
im still a little offed by it but not to bad
as i like working with there steel and they realy dont seem to mind helping you get the most out of it
butch
Thanks for the answer!
Have they announced the hardness.
Jerry Busse of Busse Combat has disputed this rumor publically several times.
-Cliff
-Cliff
no but sal did talk of his cpms125v mili proto at 63/64 Rc
and to me that sounds like it could be one hell of a blade
later i had asked how it performed and he said it did well, this was over on the spyderco home forum
so my guess would be at 62/63
crucible data sheet makes that look like a good sweet spot
butch
Your statement is wrong and very irresponsible. Feel free to contact me privately at jerry@bussecombat.com And the name is "Busse" not "Bussi".
Jerry
Dick and others, I have about 60lbs of .140 125V. At this point I have made 3 blades out of it. I would have to say this this grade is on the edge of what is practical to make a knife out of using the methods I use. The biggest problem I had with it is that it was rolled very rough. As a result it would not bond to my magnetic chuck on the surface grinder. I had to flat grind it so I could surface grind it. It ground ok on the belt grinder with a flat platen with Norton Hogger belts. Foget about cutting it with a bandsaw. I cut it into strips with a Plasma cutter and then ground to profile. I ran it at 2100 F the same as 10V and got RC 67. I tempered at 1020 and could only get it down to about RC 65. The one test knife I made was very difficult to sharpen even with a diamond stone. Once sharp it out cut every other steel on rope that I have worked with. I think the answer is to try to get an lower initial hardness to start with and maybe end up at RC 63 or so. I believe it has great potential and I am still optimistic about it. You can think about it as stainless 15V. I don't think Crucible will make any more of it, there just in not any market for it right now. I will be using up what I have probably over the next 10 years at the current rate.. Thats the story on S125V as I know it... PHIL
so grinding cpms125v was bad how was milling it i might be better off using a mill to get it close then grinding
i still think i want to try the stuff as i think it would make a hell of a folder blade also i think using it at 63 Rc would still be plenty hard for most knife uses
i fear no steel :D some just take a long time to work
DB, yes I could drill it fine. It was about RC 30. Funny thing though, I cut it on my plasma cutter and when Pc was cut through and hit the concrete it broke into pieces like glass. I think the plasma cutter heated it enough to put local stress in it. This has never happend with any other steel. When it is heat treated though it seems about as tough as say S90V at 60/60. Phil
