Exactly this, I'm also going with sharpening angle being off.make sure youre knocking off wire burr off.....that will cause super sharp and then cut something and not super sharp anymore......
How easily does K390 rust?If you're looking at pure edge retention:
S30V -> M390/20CV -> S90V -> K390 -> S110V -> Maxamet
Thus is all subjective of course. Once you get up to 20CV, who knows. Heat treat and hardness also plays a big factor.
You lose that graceful paper glide, hair shaving, hair whittling sharp pretty quick, regardless of the steel. A good steel will keep that step-below sharpness for a good amount of time, plenty adequate for cardboard, packages, food, stabby-stab, etc.
Out of those, my preferred (after years of use) is hands down K390. No chipping, good amount of toughness, and pretty much only needs the occasional strop. Good luck!
It patinas very easily, but once it does that, it won't rust unless you purposely leave stuff on it. It's a noticeable step up from carbon steels.How easily does K390 rust?
This.S35VN.
I have several knives with S30V steel. Benchmade & Spyderco. I can get a shaving sharp edge on them but with just a few soft cuts the edge is gone. Knife still sharp but not shaving sharp. What steel would be a step up from S30V?
knarfeng reply spot on, and well stated.If you want actual "shaving sharp" then you want the type of steel used for razor blades. That would be a steel without carbides. 13C26 taken to a high hardness would be the thing. Such an alloy will retain it's shaving edge longer, but would then dull much faster than a carbide-containing alloy.
Steels with carbides are like concrete, got chunks of rock in it.
Steels without carbides are like cement, just fine particles.
When you start cutting with a carbide containing alloy, the carbides (bits of ceramic) begin to protrude from the surface as the steel is worn away around it. That means you lose your "shaving edge" relatively quickly. But once exposed, the carbides wear MUCH longer than steel. That means that the somewhat lesser edge is retained much longer.
Steels without carbides do not have chunks. So the fine edge lasts longer. But then there are no hard particles to resist wear and the edge degrades faster.
I have never ran across it explained this way and now I finally understand. Thanks Frank!If you want actual "shaving sharp" then you want the type of steel used for razor blades. That would be a steel without carbides. 13C26 taken to a high hardness would be the thing. Such an alloy will retain it's shaving edge longer, but would then dull much faster than a carbide-containing alloy.
