Well guys, I must have just slopped into the right combination of belts and speed because these s30v blades were as easy to finish after heat treat as any other steel I've used and were easier than some!
I use Carbo Schroeder aluminum oxide belts from 60 grit on. I tried the aluminum oxide belts Sheffield's sells and just couldn't get them to work at all, might have been the steel or the speeds I was running them at.
I took the blades thru 320 grit before heat treat and cleaned em up with 320 grit afterwards and went right to my fine scotchbrite belt, a well used one I might add, and the blades finished out real nice. I run the scotchbrite belts and the belts finer than 220 grit as slow as my grinder will run.
Next s30v blades I grind I'm going to take them thru 500 or 600 grit prior to heat treat and see if I can go right to the scotchbrite belt after heat treat.
