In fact I like steels that have less large carbides. Not that I don't like steel with em.
yes, in that specific type of test with that specific edge. also remember these are production knives, not customs with optimal heat treatments.Lc200 scored higher than M4????
CTS-40CP "IS " 440c, same ingredients and standards as AISI, just Carpenter's own in-house nomenclature.
The main difference would be, as 440c is still a very common steel and most any foundry can and does still make it, if you buy it from Carpenter (CTS-40CP), you know rest assured it's coming from not just a reliable source, but one of the top premier steel manufacturers in the world, so it will 99%+ be a good batch of steel made with the most up to date methodology and care taken in the manufacturing process.
Sourced elsewhere, especially an unknown source, (esp. China), you have to wonder if they hit all their elements right? Maybe they only got .92% carbon, 15.5% chromium, and .67% molybdenum, all short of the threshold minimums, and maybe they over added or underadded .5% silicon to the processing, which combined all would adversely affect its performance a good deal in regards to a knife blade compared to .95%/16%/.75% which are the minimums to be called 440c.
And to answer the resurrected OP, all things being equal in terms of quality processing, cpm-s35v will still outperform it in a knife, but it's complicated stuff by comparison, and much more expensive as a result. A good batch of 440c (like CTS-40CP) however, is no slouch by any means, and at one time set the standard for all around performance, by which all the newer "super" steels (like s35vn) are measured to outperform in one or more categories, (stainlessness, toughness, edgeholding, and strength).
Dollar for dollar, cts-40cp can still give s35vn a run for it's money.
no... it would depend on the heat treatment, but if it was heat treated properly, sure it would be a premo batch. strider generally have a very good heat treatment.So as a powder-440c, that means it's pretty much a Premo-batch of 440c, every single time.
heres a graph with s35vn minus 400c...
it seems that Striders Heat treatment of 40cp is far better than most s35vn heat treatements in other mass produced knives. at least in edge retention. a custom heat treated s35vn knife could go to 62 rockwell and out cut 40cp imho. but, thats a huge price difference tho.
No, that's not what that means.
Yes, it is.
You take the exact same ingredients you use to make 440c, at the exact same tolerances, and melt them together to create an alloy the same as you would, except you use powder instead of billets and a vacuum sintering furnace, at one of the premier steel manufacturers in the world, you will get an overall better and more uniform alloy of the exact same composition then the billets. Ergo, "a better batch".
D2 vs CPM-D2
154cm vs CPM-154cm
440c vs CTS-40CP
I'm not saying that you are guaranteed a better end product, I'm just saying the beginning product, the original stock of steel that a maker acquires will be consistently better then some "440c" melted by billets in an arc furnace at "John Doe's foundry" across town. Not to say that will necessary be a bad batch either, but way more room for inconsistencies.
