kuraki
Fimbulvetr Knifeworks
- Jun 17, 2016
I bought 4 sticks of S7 through MSC to make some longer blades that I wanted to be as tough as possible. I've worked with S7 in the past building tooling and am familiar with it, so I thought this would go rather smoothly. But I can't get this stuff to reach full hardness out of the quench.
I've austentized a blank twice now and it's coming out of the quench at 54 RC both times. After tempering at 300F the first one was only 52 RC. The blank is tempering now again at 300F.
1st protocol:
Foil wrapped with a squirt of WD40, load into 1400 F furnace and equalize
Ramp to 1750F and hold for 30 minutes
Plate quench in foil
This came out straight as an arrow, no scale or decarb to speak of, and I was really happy at first because I hand sanded this to 320 grit prior to heat treat, so there would have been very little post HT work to do. I went right into the temper oven at 300 because it seemed to skate my file. Out of the temper it was 52 RC
So I tried again, 2nd protocol:
Foil wrapped with WD, 1400F and equalize
Ramp to 1800F this time, soak for 30 minutes
Then to quench, I wrapped it so I could easily and quickly pierce the foil with the tang, so I slipped it right out of the foil and quenched in oil.
This time I tested before temper and it's 55 RC :grumpy:
This MSC steel came from Precision Marshal Steel Co. I called them and they're faxing me their heat treat recipe but I doubt it's going to be much different.
I know S7 isn't going to get as hard as O1 or A2. But it should be 60 out of the quench, and 57 after temper is pretty common and what I was hoping to leave this knife at.
I'm probably going to try and get MSC to take the 3 sticks I haven't cut back and refund me, and buy some 3V instead. But this is frustrating, this blank I'm trying to harden was really nice
ETA: It's not my temperature, it's not my furnace. I hardened a Z Wear blade yesterday as well and it's exactly where it's supposed to be after plate quenching and 1000F temper.
1st protocol:
