- Apr 12, 2009
I think it may depend on the stone. I ruined a lanksy diamond hone in one trip because of an S440V Kershaw boa. I currently use my cheap stones on every kind of steel I have or have recently had, notably S440V again, S110V, PSF27, ingot D2, S30V, Elmax, and I now have Vanadis 4 Extra just waiting on me to work on it. No significant dishing or glazing noted at all. They actually do well. The only problem I see is if I'm reprofiling from something like 22 degrees plus down to about 15 degrees on thick blades with high hard carbide volumes. That takes some work. I'm thinking, though I don't know because I don't have diamond hones now, that the diamonds would work faster. I'm hesitant because of what I saw happen very quickly to the only one I've tried and the success I've seen with multiple other kinds of stones, mainly SiC and whatever the Chinese stones are.
I'm looking forward to trying some CBN and quality diamond hones like mentioned earlier by another poster.
My 'well-worn' Lansky medium diamond hone was in that condition (had some bare spots in the nickel), in part because it was the first diamond hone I'd used with any regularity, and I used it with a heavier touch than is best for them. Their other limitation is their small size (1/2" x 4"), which means it's all the more challenging to tackle really big jobs, like taking a factory grind much more acute (this is what I'd done with the S30V blade I mentioned). It's no wonder they'll wear down more quickly than more typically-sized stones (applies to all of Lansky's hones, regardless of abrasive type). All that said, there was still enough grit left on the diamond hone to finish the S30V rebevelling job, after the standard corundum (AlOx) Lansky hones stopped cutting altogether, because they'd glazed up.
After calibrating my hands for a lighter touch with diamond hones (to maybe 1/3 the pressure, as it's literally 2X-3X the hardness of other abrasives), it became much easier to get good results out of my DMT hones without putting excessive wear on them. That'll always be the killer of a diamond hone, if it's regularly used with the same heavy pressure as is often used on bench stones in SiC or AlOx; it's not necessary for the diamond to cut efficiently, and the much-lighter touch will always work better anyway, across the board.
David
