I've had this blade hanging around since 2010/2011. I was going to keep it but put it away and kept forgetting about it even after I had put the kirinite on it a few years later. Although I've been using this pattern for years the handle design has changed some to something I see more often now in the folder world and on few fixed blades. That said this older version is up for SOLDshipped without a sheath. If you want kydex add $10.00 and tek-lok add another $13.00. Specs below. Ships on the weekend if I'm making a sheath. If interested first "I'll take it" gets it or drop me a PM. I'll ship internationally but you pay the extra fees and I'm not responsible for lost or damaged items once it arrives.
Steel: S90v @ 60-61hrc. HT by Peter's. Full flat grind.
Handle: Metallic Green Kirinite with black G10 liners
Cutting Edge: 3-3/4"
OAL: 7-3/4"
Blade Thickness: .1"
Thickness at edge: .007 at the heel and .014 at the tip BEFORE SHARPENING.
Edge is thin toward the handle so use common sense. I warranty my work and will repair or replace anything that isn't right if item purchased was used as a knife and somehow failed. Warranty doesn't cover abuse.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
OAL: 7-3/4"
