Sad to say.... I've never skinned an animal
I've done a metric ton of tree rats, little bastards told their young scary bedtime stories about the shotgunnerman, checked their closets for me at night.
Aside from that, I've done a few coons and one deer.
My uncle skins out deer with the golfball method on the trailer hitch of a pickup. It's like taking off a jacket.
I don't have enough deer under my belt to say I could do it alone, but once you learn it, it's not really that hard.
I still have trouble skinning squirrels. Darned things have the toughest hide I've ever seen. Pretty much everything else is straightforward.
I once had the same question, did a search on Youtube, and came up with many videos on dressing deer. Give it a shot. :thumbup:
I hope this helps. This one has been 'gutted' already.
To gut it, you cut VERY CAREFULLY along the belly... being VERY CAREFUL not to cut too deep (maybe 1/4 inch deep), or you will puncture the guts. When you puncture the guts... you will know it... it smells like a really bad fart that does not go away. :barf: Also, this is how e-choli gets spread onto meat. Both bad.
Once you get the cavity open you will cut the diaphragm which holds the guts in the animal's body cavity along the ribcage. Think of the diaphragm as a 1/4 inch red sack that holds all the guts together. Once it is cut, you'll see the ribs.
Once the diaphragm is cut the entrails will come out with a bit more cutting down toward the neck.
To skin, simply make a cut all the way around the neck and around each of the legs at the 'elbow' and "knees' of the deer. then cut down each leg to meet the cut on near the midsection where he was gutted. Then, start skinning. Some of the skin will peel off of a deer, but on young deer it can actually rip the tender meat... so be careful (and don't have your knife in your hand if you are pulling on the hide please!).
I know this is overly simplistic and I left out some details for the sake of brevity... but hopefully it gives you a good idea. It's kinda like sex... the first time can be a bit awkward... but once your in 'there' you'll know what to do. On second thought... it isn't like sex at all... but I'm all out of metaphors... ;)
Ranger likes to beg for fresh Venison.
Last few deer and hogs I've shot, I've been practicing boning them out. It saves the trouble of gutting them and it makes it easier to carry out the meat. I'll bet there are some on-line tutorials on that approach as well.
DancesWithKnives
I could be wrong but I think that's illegal in many states. I'm pretty sure in WI at least the carcass has to be tagged and intact (gutted, of course) to register it. This may be just to prevent people from sneaking does out of buck-only areas or vice versa.
In Texas, you can have the deer quartered as long as you tag it and keep proof of sex with it, either head or the family jewels...
Where I hunt, you have to leave evidence of sex attached to some substantial part of the animal. And you don't want to be carrying more meat than would be yielded by the animal you've tagged.
Interestingly, when coming back in to California you are required to do a certain amount of boning out. Last I checked, California will not let you bring back the spine (or brain) because of concerns about chronic wasting disease, etc.
DancesWithKnives
You ain't missing too much buddy, even if ya don't do as per the guide books you will still get it done eventually.....just be ready for some bad smells when it comes to removing the guts !!!!!
It isn't hard. Just make sure you clean off the meat good once you get it out.
Once you do it once, you will remember it for the rest of your life. I'd work my way up in game size, if you really want to practice. Just make sure not to waste any meat after cleaning it.
I sure am glad I said "I could be wrong..." :D Thanks for clearing that up, gents. I can certainly understand not wanting to carry out the bones etc. I've browsed through the DNR pamphlets/rulebooks and frankly they confuse the hell out of me at times.
No problem. I'm sure what you said is correct in many areas.
Thanks for the cautionary note.
DancesWithKnives
This is a good thread. I'm just like the OP, fisherman, not a hunter. I have learned a bunch from these post-thanks guys!
Myright, there are several ways to dress out an animal that are effective. There are also several ways that people do year afer year "because thats how Pops taught me," even though it is difficult, slow or wasteful. Here are some tips I have learned for a deer or other larger animal.
You want to get the guts out of the animal without fouling the meat. You really don't want to rupture the gut sack or bladder as this can impart a really nasty flavor to the meat and make the rest of your job MUCH harder than it needs to be. :eek: To reduce the liklihood of that happening, I recommend working from the top down, rather from the bottom up. Here's what I mean:
1) First, attach your tag and place the animal on its back. (Think submissive puppy.) Use logs or rocks to prop it in this position. If there is a slight degree of slope, position the head uphill. By doing this, the gut sack will settle low in the abdomen and you can make your initial cut just under the solar plexus. As the guts should be safely out of the way, you should be able to cut through with only empty space under your blade. Nevertheless, it is a good idea to cut careful and verify that you have missed the guts. (Heart and lungs are not a problem).
2) Once you have made your initial incision, cut the hide upwards toward the head, on top of the sternum. (If you are planning on mounting the head there is a different procedure.) Above the top of the sternum, form a "Y" with cuts leading toward each leg. This will allow the hide to pull away from the carcass so it is out of your way. You may need to slice though a little connective tissue here to get the hid to cooperate.
3) Next, cut or saw upwards from your initial incision, though the solar plexus, completely spplitting the ribcage. Pull the ribcage open and prop oit that way with a forked stick. If you have eniough cordage and conveiniently situated trees, you can tie off the two sides of the rib cage so you can work unhindered.
4) Once the chest is open, reach up inside the animal's neck and sever the windpipe. Be very careful here! You are using both hands and a knife, which are proably slippery with blood, in an are where you cannot necessarily see what you are doing. One way to increase your awareness of where exactly your blade is in relation to your other hand is to cradle it with your index finger along the spine of the blade and your other hand going in second. Once you have cut loose the windpipe you should be able to pull it out, removing the lungs and heart with it. It is kind of like pulling the guts out of a trout.
5) Now you can start working your way down. Carefully cut the hide away from the abdomen, from the inside out. You will notice that the hide and skin are seperate layers. It is usually easier to cut the hide first and let it fall out of the way, then come back and carefully cut through the skin. This will reduce the liklihood of puncturing the gut sack and will minimize hair getting on the meat. Cut straight down the middle all the way down to the genitals. Go past the genitals to one side or the other and stop just short of the anus.
6) Cut around the anus, freeing it from the hide and pull it out away from the carcass. I have found that twist ties or rubber bands come in handy for sealing this bad boy up before you thread it back through the hole you cut and out of the animal. Similarly tie off the uretha and cut it away from the genitals.
7) At this point you can remove the entire gut sack intact. You'll have to slice a little connective tissue up toward the spine, but then you should pretty much be able to roll it out of the carcass. NOTE: If you pull this off on your first big game animal, all by yourself, without any help - GOOD JOB! You've just dressed your first animal! At this point you can transport the animal for processing elsewhere, hang it to cool, or continue to process it in place.
WOW! I didn't plan to go into this much detail! I'll stop here and if you want I'll pick it up from this point in another post.
-- FLIX
brian andrews... or others... do u have any pics of gutting/processing a hog? im assuming about the same but thx u so much for the pics... and thx flix for the verbal description...
Hogs are an entirely different matter. They are built like a Abrams Tank. Very tough hide (mixed with mud, dirt, grime) and very thick bones. IMO... it is a VERY good test for your blade steel. If it shaves after doing a hog... you've got yourself a good blade. :thumbup:
Anyway... I've processed pigs the same way as I process deer... until I learned differently. With a pig, you can get the meat without gutting. And trust me... you don't want to get into those pig guts :barf::barf::barf:.
To do this, cut down the middle of the back all the way down the spine. Skin back the hide far enough to remove the backstraps. You can remove the legs by skinning only what is necessary to 'get in there'. It is a much simpler process, and much cleaner and you still get 95% of the meat. Undoubtably, some scrap meat gets left for the vultures with this method. But hogs have no limit and can be hunted year-round, so I'll just go shoot another one if I want more meat. :)
That's basically my approach on deer. One difference is that on larger boar hogs, when you are removing the shoulder meat you need to work around the gristle/cartilage armor plate that they possess but deer don't.
If you are not gutting the animal but want the tenderloins (on either deer or pigs), after you have removed the backstraps you need to cut enough ribs at the spine juncture to get the tenderloins out. [Small hatchet or cleaver helps here.]
Needless to say, if you are field dressing a pig and want to make up a batch of BBQ'd pork ribs, you might as well gut the thing.
DancesWithKnives
Tip.........
If you plan on skinning, do it while the animal is still warm. It is easier.
Here is a good tutorial on deer.
I do a few whitetail a year sometimes more and I'd say that link is about as good as it gets for processing.:thumbup:
I like the way they do the hind quarter deboning, slick stuff.:cool:
Thanks for sharing.
Helle
