Saddest axe in the world
We're always posting pics of robust handsome axes but what about the sad urchins of the axe world?
Look at this pathetic specimen. As you can see someone took a broke hatchet and duct-taped it to an old table leg.
That is pretty sad. Today I hung a small double bit hatchet. The eye of the head is not so normal. Marbles decided to essentially drill 3 overlaping holes through the head. So, two grooves had to be routed out on each side. In frustration, I started beating the head onto the new handle, yes it cracked a bit.
Now, I have filled it will Truebond wood glue, and just got back from the hardware store with some Rescue Tape. Will it work? I hope so, once the glue has dried, I'll wrap the $hit out of it with this self fusing tape. It's supposed to hold 950 PSI tensile strenght. Time and use will tell.
Yes, this also might be a sad little hatchet.
