Use an old slow cooker or a double boiler.
Or just use a coffee can and low heat source like a candle at the bottom
Where do you buy paraffan wax at?
I have a doulbe boiler with a 1 quart mason jar of beewax in it that's always ready to go (since I use it more than once a week for knife stuff) and the trick is low heat, patience, and letting it get FULLY melted.
With a double boiler, would you be able to set the temperature higher than without one, in order to make the water boil faster, then lower the temp once the water starts boiling?
DITTO what fishshooter stated. If ya don't have some old pots try a small size coffee can in a pot of water. Better safe then sorry.
as others have mentioned DOUBLE BOILER only for melting wax.
other safety tips:
- MEDIUM heat only, preferably an ELECTRIC range. There is a veyr high risk of igniting wax vapours when using a GAS stove.
- Devote your entire attention to the melting pot. Do not turn away to go take a piss, or answer the door or phone. ALL eyes on the melting pot. This may seem safety nanny'ish but trust me.........i've seen what melting wax can do fire wise to a structure and a persons body.
- thick leather gloves, LONG sleeve shirt, shoes etc etc etc
- as soon as all the wax is melted, shut off the burner and move both the pot and wax pot together, THEN remove the wax pot and set away from the stove on a hard surface.
- Keep cats, dogs and KIDS away from the room. Cats like to get under our feet and no one feels good dumping hot wax on a little kitty.
