- Dec 1, 2015
Hello,
I just purchased a new sage 3 in carbon fiber from a local authorized spyderco retailer. The bolt lock on it is quite stiff. the studs really dig into my thump in finger just to disengage it. I can only do it a few times before my thumb starts to feel a little raw. My question is, is this normal? And will it break in and get looser over time? I have applied some rem oil just to check off lube as an issue. Otherwise, my first impressions are positive. I find it to be a nice middle ground between my native 5 g10 and my 940-1. The blade length is just right for my use, and the carbon fiber pattern on the handle is very pretty. Best of all, the handle has plenty of grip for an edc knife, yet is smooth enough not to cause excessive wear to my pockets. The wire clip has excellent retention and is very discreet. It becomes a little more difficult to draw from pocket because of how deep it sits, but it is a worthy trade off for discreet carry at the office and in public. Besides the stiffness, I like the bolt action lock. It is similar to the benchmade axis, but I get the impression that it will be a more durable lock. My 940-1 axis lock just broke 3 days ago after only 7 months of ownership. (it was purchased new from authorized retailer). The lock still works on the benchmade since it appears as though only one of the two omega springs broke, so the knife is still usable, so at least there is some redundancy in the design which can get you by until you can have service. Also, another nice thing about the sage 3 is how smooth the blade opens and closes, plus it does not make nearly as loud of a sound as the native 5 does when the lock engages. It seems to me that part of the reason the blade pivots so smoothly is because the bolt lock does not put very much pressure on the tang of the blade, so there is relatively little friction compared to other locking designs. However, the slight downside of that is that the blade is a little bit easier to open unintentionally compared to other lock types.
