Fred Sanford
- Sep 3, 2006
How about the Leatherman Free? You can open everything one handed. Great little tool.
Over stated budget. Also, don't the blades lock?How about the Leatherman Free? You can open everything one handed. Great little tool.
Or one of the non locking MAM friction folders.This is a really tough question. The requirement of no nail nicks and no one-handed opening basically eliminates almost all pocket knives from consideration, and certainly all SAKs and SAK-like knives. The best that I can think of off the top of my head is pairing a small Opinel (the size that doesn’t have a locking ring) with a Craftsman 4-way keychain screwdriver.
How do you extract the toothpick without using your fingernails? I just tried it, and I had to press really hard to get the flesh of my fingertip into the gap between the toothpick and the scale to get the toothpick out.What about using the back of the toothpick to open the nail nicks? The flat edge of the nub on the end of the toothpick will hook into the nail nicks of all the tools. You just push it down into the nail nick and pull back to get the tool open.
It's not my idea. I saw it in a youtube video. I think it might have been on Felix Immler's channel.
It works pretty well, but if grip strength is a problem then I don't know how effective it would be.
Give it a try and see what you think.
I keep my fingernails super short for hygiene purposes, and I have never had any issues removing any of the scale tools except for one time when I had replaced the scales with a new set that weren't fully pressed down tight enough. The scales looked fine but they actually weren't quite down all the way. Once I put the knife in a bench vice and I got the scales properly seated, the issue went away.How do you extract the toothpick without using your fingernails? I just tried it, and I had to press really hard to get the flesh of my fingertip into the gap between the toothpick and the scale to get the toothpick out.
If that had something like the Victorinox combo tool on the Waiter/Compact and, like you said, a more appropriate awl, it might be okay if the backspring tension is appropriate. For now, though, since it doesn't come like that from the factory, it doesn't really fit the philosophy of what I'm going for. Also, FWIW, I've had a few rigging knives like that, and they had monstrously strong backsprings.If one hand opening and locking blades are frowned upon, I don’t think an awl with a handle affixed to it is going to go over well.
My best suggestion, with such tight parameters, would be to check out a British Navy Knife.
Use a Dremel to make the easy-open cutouts a bit deeper and maybe add a thumb stud to the can opener. Otherwise you’re opening the blade fully, opening the can opener to half stop then close the main blade.
For an awl, grind two or more sides of the Marlin spike flat and have a hole drilled in it?
