Sal,
Here are some thoughts that occur to me as I read this and similar threads.
1. I worry less about lock failure than I do about handle failure. Assuming the knife is used in a normal, albeit very hard downward motion, what I want to know is, how hard can I push down while cutting something very tough? For example, the other day I was cutting a large chunk of beeswax with my Calpyso Jr. BM. This wax comes in the shape of a cylinder somewhat larger in diameter than a votive candle. I had to push HARD to force the blade through the wax (it's sticky!) In order to alleviate some of the strain on the handle, I usually push down on the blade spine with my left hand while holding the handle in my right hand. (Try this with a Calypso and you'll understand why I don't like the "swedge", although I'll admit it looks nifty). I really leaned into that cut, and the knife didn't break. I don't think I'm strong enough to break it in the manner described. After this cut I expected there would be at least some blade play along the longitudinal plane, and I was very pleased and a little surprised to find that there was none whatsoever. Anyway, the point I'm trying to make is that the test you describe, with the blade clamped in a vise and pressure being exerted downward on the handle aft of the pivot, seems applicable to something other than the forces generated during normal cutting. What you would need to do, rather, is clamp the *handle* in the vise and exert *upward* pressure on the *edge*. Does this make sense? Do you test knives in this way? I suspect you do. Maybe your machine does exactly what I'm talking about.
2. Assuming the kind of cutting I've just described, and assuming I'm strong enough to hold onto the knife under any circumstances, how much would I have to weigh to break (a) a FRNR Endura; (b)a FRNR Delica; (c) A Calypso Jr. BM; (d) a steel Calypso Jr.; (e) A Military? This would certainly put things in perspective for me.
3. For me, perhaps a reasonable and not too arbitrary standard for a "hard use" knife would be the ability to survive the sort of cutting I described in #1 above, with the entire weight of a--shall we say--250 lbs. man pushing the edge downward while holding the knife by the handle. (By the way, I way 165 lbs.)
4. When you talk about a folder being safe for the ELU, I assume you're talking about the danger of accidental closure of the blade, as when pressure on the spine causes the blade to collapse onto the hand. If THIS is what you're talking about when you speak of "400 lbs...hard use...etc.", then that's something altogether different than what I'm talking about above. Obviously a different kind of testing would be necessary, something on the order of grasping the knife by the handle and lifting a heavy table by pressing upward against the bottom of the table using the spine of the blade.
5. I'm still unsure which kind of strengh you're talking about: cutting downward with the edge on a piece of beeswax, or lifting a table with the spine of the blade?
6. Obviously both kinds of reliability are essential in a hard use folder.
I'm sorry if I'm being a pest. I'm not challenging your criteria for "hard use" folders, nor am I questioning the validity of your testing. I'm just making sure we're on the same wavelength, so to speak.
Thanks.
David Rock
