Hey Michael-
Saw this before your message.
I have done it a few dozen times, but I don't recommend it. The moisture was never an issue in my shop. Never had one cause the salt to "spit" even a little bit. I would put the clayed up blades in the oven at tempering temps for an hour. Since it only takes a minute or two to reach austenitizing temps in the salts, you want to make sure you have your tempering oven up to temp anyway.
However, putting the clay in the salt will make the salt go to hell in a hurry. You don't have to do this very many times before the salt will start to create a bunch of nasty scaling in the blades.
All that aside, I never got any crazy great hamons by doing it. I have gotten a lot of crazy cool differential hardening with salt simply by manipulating its super tight control over time and temp... but those were bare blades with no clay.
For clay hardened blades, I haven't found anything better than a forge with nice, even heat and a digital temp monitor. This is IMHO far superior to a kiln, because you can take the blade out to check it as often as you want, with only a slight deviation in temperature (that quickly climbs back up anyway).
Where the salt excels, IMHO, for a hamon chaser is in all of the thermal cycles you can do with them, prior to austenitizing.![]()
