Samurai Edge Sharpening is Back!!!
I find this to be a fascinating subject and I am looking forward to seeing Andys pictures.
Question for Andy: What shape are the edges Mike makes, are the flat or convex? I know the edges on traditional Katana's where where convex so I am curious how Mike does them.
Thanks!
...he has done convex with other equipment for other cutting instruments, but his edges for knives are "V" ground.
I just got my copy of the Knives Illustrated article today....I will try to have pictures up by this weekend.
Andy Prisco,
Co-Founder, Manager
American Tomahawk Company
877-557-5200
http://www.americantomahawk.com
One point that should be clarified is that there is a significant difference between the Japanese Waterstones that you buy from say Lee Valley for around $25 - $50 (depends on grit) and natural Japanese Waterstones which can cost ~$1000, so a full set could run you ~$10 000. The quality also varies significantly and it is far from trivial to pick out the good ones. Most traditional Japanese woodworkers tend to prefer the natural waterstones, one possible reason being they have a very "soft" action which is well suited to the *very* hard and thin blades they tend to use.
Now I am not making the argument that traditional methods on natural waterstones are "better" than modern power equipment with various abrasives. But there are significant differences; the initial cost of the equipment, the training required, and the time it takes to sharpen a blade using it. In general you can expect to pay much more for something done by traditional methods than a "replica" by current methods, even if the current methods give an equal or even better performing product. That being said, the prices seem reasonable to me, just in regards to the traditional aspect.
To clarify the comment I made in regards to slicing, to me, slicing means cutting with a vastly reduced amount of force in comparision to push cutting the same material. To be specific, as an example, the Buck/Strider folder I had with a shaving polish would push cut 3/8" hemp rope with about 100 - 110 lbs of force. If I lowered the finish to 600 grit (DMT rod), I could drop the force to around 35 lbs and cut the rope in 2-3 slices. If I kept the finish high and tried to slice the rope, I would need pretty much the same level of force as on the push cut and that would be basically what I was doing as since the teeth are so small the amount of material they shear through on the draw is not significant and thus it not really slicing.
Now various steels act slightly different in this regard, there are some that will retain much more of a "bite" at higher polishes than others, but even they are no match in regards to slicing at a high polish as compared to themselves at a lower grit. I am not talking about small changes like 10% either, but much larger effects like several hundred percent. There is nothing complicated about this, you are just comparing basically the action of a saw which requires low vertical force to an axe which requires a lot.
Jerry :
<font face="Verdana, Arial" size="2">I'm often surprised by the comments on repeated sharpening on these forums. If it's done right it doesn't need to be done often.</font>
Blades tend to have to be sharpened every day if you want to keep them near optimal performance, assuming they are used of course. As an example, Busse Combat has posted various performance specs for the INFI line, one of which is something like 24 pieces of 2x4 before the blade loses razor sharpeness. This isn't a large amount of wood if you are burning it. When I take the BM out to cut up enough wood for a couple of days I will go through several times that amount. I am also not cutting up clean lumber, but through bark which will contain dirt and such that will obviously blunt a blade much faster . It is not just chopping either. If I am breaking down cardboard boxes at work, they will be dirty and again dull a blade fairly quickly. Same thing for most uses, a large number of tests quote say 100+ cuts on hemp rope, well yes if it is new store bought rope, try the same thing on used cord.
<font face="Verdana, Arial" size="2">Polished surfaces are more wear resistant than rough surfaces. </font>
The wear resistance of a steel has little to do with the edge retention in most cases as regards to immediate blunting as it is caused by deformation and/or fracture. The only time it is really significant is if you are willing to work with the knife at much less than 100% performance. The main benefit of greater wear resistance is to basically increase the time that you can get between honing by allowing the use of maintance techniques which align the edge such as steeling and as well reduce the amount of honing you have to do when you do need to fully sharpen the blade as it loses very little metal in use. There are exceptions to this, but you have to be cutting very abrasive material which is capable of wearing a significant amount of material off of a high alloy steel in a short amount of time, like used carpet for example.
In regards to the wear resistance of rough vs polished surfaces, yes a polished surface does wear better, however you have to remove a significant amount of material off of the rough surface when you polish it. If you subtract this out of the material lost in the wear testing, then they are not nearly as different. For example, as an easy to picture case, take a two files, now polish the teeth off of one. Now use both files on say concrete. You will note that yes the teeth will wear down much quicker on the NIB file than the flat surface will abrade on the one you polished, but the NIB one has to have the teeth all worn away before it even starts to wear on the same surface that the polished one is wearing on right from the start.
Anyway all that being said, polished edges do resist fracture and deformation much better than coarse ground ones for the same reason that a plain edge blade is more durable in regards to twisting, impacts and hard cuts than a serrated edge. For these reasons, high polished edges will readily outlast coarse ones on harder work like chopping. They will also readily outcut them in push cuts (require much less force), but will be themselves outperformed greatly in slicing vs coarse ground edges.
-Cliff
[This message has been edited by Cliff Stamp (edited 03-07-2001).]
Hmmm,
Cliff, I wonder if to a certain extent this is material specific - meaning the material being cut.
When you are doing a pure push cut, the only factor in starting the cut is the contact area of the edge. As you penetrate the angle of the edge, which is controlling the chip formation effects the pressure also. Thus, the closer to perfectly intersecting lines the lower the starting pressure.
When you are slicing, I would have thought that some of the same effect would exist. You still are applying pressure. I could see the sawing effect being greater on something hard, like a dried wood, where chips form cleanly from the sawing action, but in something like a piece of steak, I would think that the push cutting effects would overcome the sawing effect.
With the testing that you have done, have you done any experiments comparing cutting performance in hard vs. soft materials? Actually, I'm not sure the distinction would even be that simple, because at a microscopic scale, you get chip formation in cardboard just as you do in wood, same with paper, but not in meat, or some plastics.
qwertyname:
<font face="Verdana, Arial" size="2">I wonder if to a certain extent this is material specific - meaning the material being cut. </font>
Yes, there are materials that you can slice easily with a highly polished blade, like the steak you mentioned, however this is simply because you can easily push cut them.
<font face="Verdana, Arial" size="2">When you are doing a pure push cut, the only factor in starting the cut is the contact area of the edge. As you penetrate the angle of the edge, which is controlling the chip formation effects the pressure also. Thus, the closer to perfectly intersecting lines the lower the starting pressure.</font>
Yes, the blade angle can actually turn a pure push cut into a slice. For example I was comparing the push cutting ability of the PAB from Strider to the Battle Mistress on 3/8" hemp rope. I found that even though the BM has a much thinner profile, if I used a rocking motion and took advantage of the curvature near the top of the PAB's blade it would readily out cut the BM (don't have the figures on me, but will be in the review this week). With a straight on push cut the BM readily outcuts the PAB.
You get the same effect on just about any material, for example using a skew chisel on wood. Because the cut through the wood is not part slicing and part push cut instead of just straight on push cut the force required is significantly smaller. For this reason skew chisels will have lower edge angles. If the blade sees less force you can get away with a thinner profile and still have the necessary durability / edge retention.
<font face="Verdana, Arial" size="2">in something like a piece of steak, I would think that the push cutting effects would overcome the sawing effect.</font>
Yes, simply because on a knife with a decently thin profile and polished edge will go right through steak with little force, just its own weight is nearly enough.
<font face="Verdana, Arial" size="2">at a microscopic scale, you get chip formation in cardboard just as you do in wood, same with paper, but not in meat, or some plastics.</font>
I should have been clearer, I was a little vague. With a coarse edge when you press down the "teeth" bite into to roughly their depth. The force required to get penetration above this is vastly more because you have to force the blunt gullets (the space between the teeth) into the material and they require much more force to achive the rupture pressure of the material (what pressure is required for it to be split apart). Now when you draw the blade across the material the little teeth rip through the material in the gullets which allows the teeth to drop down into the material again and the cycle continues.
A couple of things are required in order for this to be practical. First of all the teeth need to be of a decent size. If they are very small (a very high polish) the penetration they get (and thus the material cut through when they tear through the gullets) is too small and thus the blade just skims across the material not doing much of anything unless you apply enough force to drive the blade as a whole through the material, teeth gullets and all, ie. do a push cut.
Secondly there much be a lot of dead space in the material for a couple of reasons. Primarily because you must be able to force the blade into the very small tract opened up by the teeth. If the material is loose (and even better under tension), such as with most ropes, fabrics, webbing etc., things that are normally sliced, this is the case. Otherwise if you need a huge amount of force to push the blade into the cut opened up by the teeth you are better off polishing the blade and doing a straight push cut or using teeth that can clear the material out of the way to make room for the blade (this is why teeth are set at an angle in a saw).
One of the best (or worst depending on how you look at it) materials I have found were some fabrics sent to me by Donna Barras (hope I spelt the last name right). They are very difficult to push cut as they have *very* high rupture pressures.
-Cliff
$40 and up + shipping to sharpen 1 knife 1 time? Got to agree with RJ. Wow, I will not even spend that much for a system or stone I can use on all my knives. Btw I get an edge that will push and slice very well. I think alot depends on the scratch patern you get wile sharpening. Also rounding off the sholder of the bevel and getting the face of the bevel polished and just leaving the edge tip caurse is what I work for and seems to give me great cutting performance with both push and slice cuts.seems to work for me. Also all steels don't act the same and will take me a few times to learn how I need to sharpen it to get what I want.
db:
<font face="Verdana, Arial" size="2">rounding off the sholder of the bevel and getting the face of the bevel polished and just leaving the edge tip caurse is what I work for</font>
This is a fairly important point, having the whole edge bevel left coarse doesn't give you any advantage and just increases the force necessary to drag/push the blade through the material.
-Cliff
Ok, thanks for the clarification Cliff, this is pretty much consistent with my experience and analysis as well.
If we extend this a little bit, assuming for a moment that you could have a theoretically perfectly sharp edge, where the edge area approached zero, then the force required to initiate a cut tends toward zero also. (Pressure = Force/Area)
Now in reality, you obviously cannot have an infinately sharp edge, but it actually should be possible to quantify sharpness based on a microscopic view of the edge itself. I've never really done this, but where I am leading is that at some "level" of sharpness, or better stated, some small enough contact area of edge, the reduction in force to initiate a cut should reduce beyond what can be had in the "micro serration" model. At least theoretically, if the "pure" edge had a smaller contact area than the summed area of the "micro serrations" making contact, the "pure" edge would out cut the "micro serrations" under most any conditions - all things being equal with bevels, thickness, etc.
Now, in a practical sense, has anyone ever gotten something that sharp? I know there are alot of anecdotes about "scary sharp" stuff, and I have my own of course, (all of which are fun to hear - well most) but at the moment I am curious if anyone has done any tests to check something like this, and if not, Cliff, assuming I haven't gone off my rocker in the analysis, do you have some thoughts of how to set something like this up using an aformensioned "Samurai Sharpend" blade? (Yep that was a really long sentence). I'll do some thinking also if it is something you are interested in trying to test for.
I have a $100 foot long black Arkansas stone. After purchasing it I discovered that my knives cut better not using it.
I have the 3 Norton foot long oil stones in the oil bath. I have a foot long leather strop that I use 10,000 grit chromium oxide on. I hand sharpen with a guide. My knives shave chest hair without touching skin.
I used to go Norton, Black Arkansas, strop. Now I leave out the Black Arkansas. Bob Dozier tells me he heat treats his D2 for "large" grain size...says it cuts better.
I haven't noticed a decrease in edge life after quiting polishing my edges with the Black Arkansas. I do scratch my head when I hear myself recommending not polishing an edge with the Black, when I strop my edges with 10,000 grit. I just know that's what works for me: both better push cutting and slicing when I omit the Black.
bug
qwertyname:
<font face="Verdana, Arial" size="2">you obviously cannot have an infinately sharp edge</font>
No it will be limited by either the grit of the abrasive you use or the properties of the steel (carbide size and grain size). For optimum polish go with a very fine grained steel like 52100 or CPM-10V . I would assume that 52100 would be a bit better because the vanadium carbides in 10V will not actually be cut by the finer abrasives.
<font face="Verdana, Arial" size="2">it actually should be possible to quantify sharpness based on a microscopic view of the edge itself.</font>
Yes, the cross sectional area, there are several books which show edges at various levels of polish. Measuring it this way in a numerical manner would be possible, but would require some not so cheap equipment.
<font face="Verdana, Arial" size="2">at some "level" of sharpness, or better stated, some small enough contact area of edge, the reduction in force to initiate a cut should reduce beyond what can be had in the "micro serration" model.</font>
The amount of force necessary for the teeth to penetrate is very little compared to even the highest polish. Consider that the teeth basically go to a point limited in area only by the properties of the steel. This is as best you can do with a polish, however with a polish you have to push the whole edge into the material, with a coarse edge only the tips have to go in.
There is also another factor as well which increases hugely the slicing ability of coarse edges by vastly reducing the amount of force necessary to push for the main body of the blade into the cut. When you draw a coarse edge across the material, as the teeth cut through the material in the gullets, because they are uneven they will cut a track wider than themselves (you can assume say that the track width is proportional to the teeth length and thus inverse to the micron level of the abrasive). Thus the blade above the teeth has a bit of leeway when going into the cut. As you increase the polish the track opened up gets smaller and smaller making it necessary for the blade to exert more force to wedge the cut open.
<font face="Verdana, Arial" size="2">do you have some thoughts of how to set something like this up using an aformensioned "Samurai Sharpend" blade?</font>
There are lots of ways to easily show the slicing ability of blades. One way very straightforward it to take some light cord and tie it under tension say between the legs of a chair. Now draw a blade across it using justs its own weight. You can measure the length you needed to use and thus rank its slicing ability for various grits. Ideally you want a cord that light that you can slice it with one full stroke at the highest polishes and then just use the inverse fraction of the performance at the coarses finishes. Since you are using just the weight of the blade the force will be decently constant over the various grits. You want to take a decent number of cuts with each grit to obtain a stable average (or median), as changes in angle and such can effect the results badly. You can also quantify the polish of the edge by push cutting through really light thread tied in a loop through the hook on a spring scale. You want to use thread very thin so that you minimize the effects from the edge bevel and focus on just the very edge.
In regards to increasing grain size, this will improve slicing ability for the same reasons that coarse edges will, but it will also decrease push cutting ability for the same reason. It also decreases strength and durability and lowers wear resistance.
-Cliff
Large grain: shaving chest hair without touching skin is push cutting.
bug
Andy,
Any pictures available yet?
Semper Fi
-Bill
Yes Andy, when you have the time please post pictures and the article. I am realy looking forward to seeing them.
Cheers,
JD
Ok, I may have come back to where I started with this, but I was thinking about it over the weekend, and have come to some conclusions, at least in my mind.
In materials with high elasticity, such as rubber bands, flesh, tendons (which are not dried) and the like, the polished edge should be better under any circumstances, because at a macroscopic level, the materials will have the same friction on a rough or a polished edge (within reason on the roughness) and since these materials don't tear or saw particularly well, and do not retain a cut channel after one has been started, the polished edge should be superior to a rough edge. I have verfied this with rubber bands at the least. (Take rubber bands, stretch them between two nails and measure the length of cut the knife must take to sever them.)
Chopping, I think, is essentially a type of very vigorous push cut, so in principle, all others being equal, the polish should be better here.
Cutting/slicing in the less elastic materials, cardboard, rope, paper, hard plastics, metals, bone, etc. Would probably do better with the course edge.
Ultimately, you should always be able to get a polished edge which is finer than a course edge, simply from alignment of the carbides and other particulars. When I think of polished edges, I typically think of those finished with something like a buffing wheel, rather than just a very fine stone.
So, the application should actually determine the sharpening method. Which is back to where I originally started. Hmmm, does this seem reasonable?
qwertyname:
<font face="Verdana, Arial" size="2">In materials with high elasticity, such as rubber bands, flesh, tendons (which are not dried) and the like, the polished edge should be better under any circumstances, because at a macroscopic level, the materials will have the same friction on a rough or a polished edge (within reason on the roughness) and since these materials don't tear or saw particularly well, and do not retain a cut channel after one has been started, the polished edge should be superior to a rough edge. </font>
If you cut elastic materials with a coarse edge and a polished edge you can see the difference in the surfaces under a decent scope. A coarse edge will outperform a polished one because it penetrates under less force, cuts deeper on the draw, and leaves a wider track. The latter two are self-influencing, the wider track results in less force being wasted on pushing the material apart for the main body of the blade and thus gives more force to the edge resulting in a deeper cut. To get out of vague notions, here is some work :
I used a large Henckels Chef's knife, simply because I knew I was going to be grinding a lot of metal off and didn't want to waste the steel on a better knife. I cut two kinds of materials, 1/4" poly rope and 1/2" rubber tubing with 1/8" walls. Both materials were cut under tension and the only force used on the downward drive was the weight of the blade. The cutting was done with the finish of an x-coarse DMT and a fine DMT hone, 220 and 600 grit respectively. A dozen cuts were made for each type of material and the estimated blade length required to complete a cut was the measurement of the "cutting ability".
For the 220 grit finish, a cut of the rope took on average 0.61 +/- 0.04 of the blade length. The results on the rubber were similar, 0.80 +/- 0.08 . When the finish was bumped up to 600 grit the performance dropped off significantly. On rope it now took, 5.9 +/- 0.7 blade lengths and on rubber 2.2 +/- 0.1 blade lengths. So comparing before and after, at the higher polish on rope the blade cut 10 +/- 1 % as well as it did with the coarse finish, on rubber it was 36 +/- 4 %.
600 grit is not overly fine either, I started a higher grit finish, 1 micron SiC, but the knife was just friction buring the rope. Now it should be noted that there are steels that will retain a decent bite at high polish, those with a large grain structure and very coarse carbides, D2 for example, so you will not get as dramatic a loss at high polishes as exhibitied in the above. However even with these, the polished edges will never outslice the coarse ones, they just won't suffer quite as much as they do on some steels.
<font face="Verdana, Arial" size="2">Ultimately, you should always be able to get a polished edge which is finer than a course edge, simply from alignment of the carbides and other particulars.</font>
You can't align the carbides, these are at fixed positions in the steel matrix. And the limit of the finish of a polish is very basically the finish of the point of the teeth on a coarse edge. And the surface area of a polish edge will be *much* greater than the points of the teeth of a coarse one so it will always be readily outperformed on very shallow push cuts (under the depth of the teeth), which is what slicing is. If you are not slicing in the manner you are doing a push cut and then, yes, polished edges will easily outperform coarse ones as the gullets in between the teeth on a coarse edge have to be mashed through the material which requires tremendous force compared to the points.
-Cliff
[This message has been edited by Cliff Stamp (edited 03-22-2001).]
Well.....I am making progress. I have taken hi res digital images of the article...it is several pages.
I will send them to my photopoint account and arrange them in order for viewing here.
Cliff.....I called the other day and you were out. Let's talk Samurai Edges and Hawks off line.
Andy Prisco,
Co-Founder, Manager
877-557-5200
No problem, I will be home 2 hours from now. I'll email you be number again in case it got sucked into the great internet vac.
-Cliff
Cliff....we missed eachother. If you can call me approx. 9:00am EST on Friday at 201-493-2469, that would be great and then I will call you back so it can be on my dime. If you get VM, just leave a number that I can reach you at.
Andy Prisco,
Co-Founder, Manager
877-557-5200
