Since this conversation seems to be going on, I will also point out that I use 3/8" thick 1095 and .270" stainless on each side.
Alloy/carbon migration happens at WELDING HEAT if it's going to happen at all during things we makers do.
And because of this, I want to stay at welding heat as long as I possible can. And I want my billet under the press and hammer as many times as I can make it happen.
I want that steel to become ONE.
And it does.
It's also a reason why you see so many layers of migration in my etched blade.
Many guys do the "wham-bam, thank you ma'am" san mai weld.
They start with three layers of steel that when all put together are nearly at their final dimension!! As such, they spend very little time at welding heat and also experience a lot of welding failure.
I do not say this lightly - I have never - EVER - had a welding failure with my method. And I have made a sh** pot full of San Mai, and taught a few of the guys out there selling it.
Also, I think the title "San Mai" is misused quite a bit.
Fella takes three layers of something, welds 'em together and call them 'San Mai'.
The idea of San Mai is that it is a tool steel core surrounded by a differential jacket for toughness or rust resistance.
That is NOT putting 203E on W2, or 15N20 on 1084, etc.
"San Mai generally refers to knives with the hard steel hagane forming the blade's edge and the iron/stainless forming a jacket on both sides. In stainless versions, this offers a practical and visible advantage of a superb cutting edge of modern Japanese knife steel with a corrosion resistant exterior. In professional Japanese kitchens, the edge is kept free of corrosion and knives are generally sharpened on a daily basis. Corrosion can be avoided by keeping the exposed portion of the non-stainless portion of the blade clean and dry after each use."
The stainless is used for corrosion resistance and the "iron" (wrought iron) is used because it will not harden and it offers differential properties.
As a complete aside to this, the term Brute de Forge has become totally bastardized as well, to the point that anything left with a little forge scale on it is now called BdF, when, in fact, forge scale is only a matter of forge atmosphere and has nothing to do with the PROCESS of forging at all.
