Don t push me
Don t push me
Don t push meYou know that I don t give up that easy.......I will make if necessary roll mill with one meter Dia. rollers , IF i know that that will work
Both of those appear to be McDonald rolling mills with foot pedal actuation. (You can see the guy's knee in the first video on the right kicking down the pedal) They're not developing huge tonnage.
I think the problem with setting welds in a rolling mill is likely going to be too much deformation causing delamination on the end not currently in the roll. With a full perimeter MIG weld around the seams, that may be prevented. Otherwise it's no different than trying to set welds in a hydraulic press with round drawing dies. You can to it, but it's a lot harder than with nice big flat dies and even pressure.
Drawing evenly once welded, to thicknesses very hard to accomplish with a press, seems to be a rolling mills biggest usefulness.
At the last hammer I was at, the host had a rolling mill to draw out billets. They said the pattern distorts a bit, in a chevron shape. Something to consider.I say do it, and if it doesn't work for welding, I may buy it from you for drawing out billets with minimal distortion of the pattern.
(Depending on the cost to ship, of course....and if you don't use the 1mm rollers....
Well this is most simple tool to make , maybe I will .... I have laying around shop material to build ten not oneI say do it, and if it doesn't work for welding, I may buy it from you for drawing out billets with minimal distortion of the pattern.
That's not all that happens. Your material is also pushed toward the edges. It's going to "squirt" material on the backside, even if to a small extent. I think getting material hot hardnesses that are similar enough and dimensional uniformity close enough will be the devil.I don t know............... what is happening when we rolling steel is this ......the material is pushed in the reverse , towards thick side ,BLUE arrow on picture ? Welding is happening outside of rollers/ and between rollers pass already welded steel ??? How that can shear/ delaminated weld ? Why I think that pressure is just in right place to weld ? I m just loud thinking .....
One more note .I think that jewelry roll mill is better for this because both rollers are driven by motor or handle whatever is ....that must make difference ?
Thanks ! Another night without sleeping , thanks for thatAs T tkroenlein mentioned, rolling mills indeed are indeed used for producing clad materials. This is done, however, with the idea that flow stress must be reached in the weld zone. Reduction is in the 30-40% range, as far as I'm aware.
N Natlek , if you want to read further, search for "hot roll bonding".
Also FYI forces in rolling mills push both ways, and there's a neutral zone where they balance.
But yeah, build one, try it out, if it doesn't work for san mai there are lots of other uses. I can certainly relate to the urban concerns for power hammers.
That said, I thought I saw a blacksmithing forging press (hydraulic) that had an auto cycle for drawing things out - you just hold the pedal down and it reciprocates your present stroke. That ought to be pretty versatile and consistent.
I think that's on the press that JTknives made.That said, I thought I saw a blacksmithing forging press (hydraulic) that had an auto cycle for drawing things out -
Are you referring to the picture at 2:29? If so, I read that to say that welding the steel is a separate process and done before the rolling (at 2:38).I don t understand welding picture on video ..... ?
Yes ..but look further on 2:38 ...rough rolling. Looks like only end was welded ? Maybe they mean on welding sides with billet welding ?Are you referring to the picture at 2:29? If so, I read that to say that welding the steel is a separate process and done before the rolling (at 2:38).
Yes ..but look future on 2:38 ...rough rolling. Looks like only end was welded ? Maybe they mean on welding sides ? billet welding ?
