sanding and shining my kvluk
I started with 120 grit, then 220, 400......& then to black compound and a hard wheel. Finished with white compound and soft wheel. Had a water bucket next to me and used long or wide strokes. Just be careful not to keep working one spot, spread it out.....having trouble putting it into words. But keep changing location rapidly, so the heat doesnt build in any one area. Its easy to ruin the temper or heat treatment.
Funny about the acid etch, I had some ideas (old kitchen knives), picked up some ferric chloride. ....and the ideas vanished. How did yours come out? Or did you do a solid patina?
I swet sanded with 120 grit, then 220, 400......& then to black compound and a hard wheel. Finished with white compound and soft wheel. Had a water bucket next to me and used long or wide strokes. Just be careful not to keep working one spot, spread it out.....having trouble putting it into words. But keep changing location rapidly, so the heat doesnt build in any one area. Its easy to ruin the temper or heat treatment.
Makes sense - I understand exactly what you are saying.
I'm pretty happy with the patina, just used vinegar. (Pics below) But if I get another Villager Knife I may want to go the route you went an polish it. I like how yours still has a rough look and shows off the hammer marks.
Can you recommend specific polishing compounds I should look for?
Wow, the handle on yours is amazing. As far as compounds, im using porter cable black, blue, green and white. On this job, I only went from black to white. I have some red rouge that came with my dremel and white that came with a leather strop. Each company will use different colors. Mine are from lowes, picked them up with my bench grinder, plus I got 4 different cloth wheels at ace hardware from hard to soft.
I use ballistol for everything, metal, wood, leather. Its the only natural (mineral oil base) product that really works wonders. Put on a heavy coat and let it sit. After 5-15min wipe it off with your oily rag. It cleans barrels, even the tracks on my sliding doors. They went from closing with two hands to two fingers and it lasts for 4 months. It supposedly bonds with the steel, almost as good as the new synthetics, but not poisonous, , so no gloves or respirator needed. The germans made it so it would be antiseptic, so they could use it on cuts too. One product the solder could carry for most everything, they even said you could drink some for stomach problems. ....but I would not try that EVER. A good example is the 380 keltec, using clip. After a week in florida humidity and sweat, everything looked good until I disassembled and the entire outside of the barrel aas rusting. Changed to ballistol and have never had a problem again.....instead of cosmoline they coated a rifle with it and buried it for 20 years or so. Dug it up, wiped it off and fired. No rust. Just dont buy the aerosol, way too expensive. I have some small, cheap, pump bottles that I refill.
Its also nice when I cut myself working on a blade, ive never had an infection or problem.......just the other day I was sharpening a srk 6" & had to reach for something...it fell and like an idiot I instinctively tried to catch it....
Wow, I didn't know that but the last couple years I've become a Ballistol fan too. Use it for everything as well. Seems like good stuff.
Hey, I posted a long response, but dont see it.....its a rough day. ..I started with 120 grit wet, 220, 400 and then switched to black compound and a stiff wheel. Then white with a sore wheel. Really careful to move constantly and change from one area to another every pass or a few passes. Bucket of water at my side.
Started dating a German girl a few years back and she had it in the house. Its become my go to product. I rubbed it into the kvluk handle when I got it, dont know if that was good or bad.
I use it on my handles. As long as you don't want to finish with something other than oil it won't hurt a thing.
If you go for a shiny or what I call fake shiny polyurethane type finish it might not adhere well but once it soaks in good it might still be ok.
Great - Thanks! I'm at Lowes pretty often. I'll grab some next time I'm there.
Its funny, I like the handle on this one so much. I thought the kvluk handle was good, was pretty happy with the reshaping, moving the ring toward the blade, etc. Now im amazed at good the grip can actually be. I had thought it was jus t a matter of hand strength and with practise and endurance, i would get a solid,......naturally strong and commanding purchase on the grip. This little planchok arrives and my eyes grew wide, such an amazing difference when the handle when the handle works for you.
PS. The shape is very much like a sirupati. I dont know if its because of the light weight, but next to the kvluk its very noticeable that the blade stays narrower in its depth and doesnt have the belly swell. Being the kvluk is only 19oz, its not much of a swell, but next to each other the differences become apparent. .....
I couldn't be happier, when I ordered my first kukuri, this is what I was dreaming of.
And all that for only $65. A blade you can swing all day working, fast, nimble, unbelievable grip. Like I traded a local for the blade in his hand. It just doesnt get any better.
Thanks Yangdu and Karda (sorry, its already a blurr), I wish I could hide in your luggage the next time you go and see the villages, eat and drink tea with the people who live there.
