I am not familiar with the belts you are using. Are they zirconium?Do the ceramic belts cut faster than the ZrO belts? I've used ZrO, but if the ceramic belts cut faster, I may have to switch and give them a try.
The ceramics are very aggressive at higher belt speeds. I run a 3 horse kmg running at 5400 surface speed per minute. It moves a lot of metal.
Fred
Yes, they are zirconium oxide (zirconia, maybe a dioxide, I'm not sure), the blue belts, at least mine are blue. Supergrit.com says they are for wood and metal, and the ceramics they sell are listed as metal only. I used 40 grit for roughing 1095 before convexing with an 80 grit aluminum oxide. The aluminum oxide cuts slower, but the belts stay tighter longer for convex grinding. That blade cracked, a lot, so I have nothing to show for my work, but the 40 worked pretty quickly. Its about time to restock on belts, so I'd like to get the fasted cutting and longest lasting ones around, even though I only make about 2-3 knives per year, if that.
