- Mar 19, 1999
I've been making handmade knives off & on for about 15 years. Pretty much fixed blade, full tang, hunting & utility style knives. After I profile my blade, drill pin holes, and hollow grind, I'm at the part I really dislike. I lay a sheet of wet/dry sandpaper on a steel plate, squirt some Cool Tool II on the sandpaper and sand...sand...sand. I dislike this part of the process and wind up procrastinating completing blades that can then be heat treated and completed with bolsters & handles. The only part I really want sanded is the part of the blade above my grind line and in front of where the bolster will be.
I'm currently working on blanks made of S30V. OMG this stuff's hard to sand. I start with 80 grit, then 150. If I can get past the 150, then 220, then 400. It takes forever to sand away the "micro dimples" in the steel. I spend hours at mind numbing, tedious, sanding, just on the 80 grit.
I don't remember D2 & A2 taking this much time to sand.
Is there another way to finish the blade surfaces? I'm looking for ideas on what others do at this point to finish the flat non-handle part of their blades. Or, do I just need to go back to using D2?
Thanks,
Bill
Thanks,
Bill
