Point is this ..........CARBIDE contentstellite or talonite are about only 50 HRC .....Can REX 121 with 71 HRC outperform them in wear resistance ?
I understand what carbide content means and don't recall asking for anyone to clarify what it means.
A hardness test won't always tell the whole story. Most hardness tests are checking for indentation, which is useful in general terms but doesn't really reflect hard carbide particles' true hardness. Think of it this way - put a bunch of diamonds into some modeling clay. You can EASILY push the clay, but the hardness of the diamond wouldn't be reflected well in an indentation test.
Does anyone own one of these?
It’s not even the sharpening it’s the fact it is brittle and will chip like crazy.
The spine is .9mm not the thickness behind the edgeWell , for what it's worth....... 0.9mm behind edge and 42° cutting hollow grind edge....my meat chopper have better edge geometryWould I buy this ? No ! No matter how flexible it is ....it is Tungsten carbide .It will chip easy and risk to break at half is high........it s not good even for apple
There should be a sticky on what ‘behind the edge’ means vs. spine thickness.The spine is .9mm not the thickness behind the edgeThe 42 degree inclusive angle is likely to help protect against chipping.
Well, the spine is behind the edgeThere should be a sticky on what ‘behind the edge’ means vs. spine thickness.![]()
So very true.Well, the spine is behind the edgesome one would be confused.
My clever is 0.5 mm behind edgeWell, the spine is behind the edgesome one would be confused.
Liars...................This technology has excited me more in terms of a WC knife.
I wonder how they measured that it is 42 degree inclusive angle when it is hollow grind edgeThe spine is .9mm not the thickness behind the edgeThe 42 degree inclusive angle is likely to help protect against chipping.
I think this is just conventional TC in a kind of San Mai composite sandwich . Cool but nothing revolutionary .This technology has excited me more in terms of a WC knife.
