- Nov 25, 2006
Great advice, heat the vinegar first, use cider vinegar and most important is to remember that vinegar is a chemical. More specifically an acid, albeit a mild acid but an acid nonetheless so as such you need to stop the process once you're done etching the blade otherwise you get spotty results. Before you pull it out of the vinegar fill another wine glass with water and some baking soda to neutralize the acic then rinse it and pat it dry, don't rub it but pat it completely dry before you give it a light coat of oil, it'll set with time. If you want a patina the food method is best, apples, strawberries, relish, mustard all make for interesting patinas.
In my opinion a natural occurring patina is best. Just use your knife, keep it clean and dry and it'll build layer upon layer of a natural lasting patina. The one I have on my Case Swayback Jack is like anodizing it's so tough, I tried to polish it back up and I couldn't get it all off even using steel wool. There's lots of advise in maintenance and tinkering on forcing a patina. I'll see if I can find a couple for you.
Thank you for sharing additional information sir. I am still into my cutting tools, but the roaring flames of lust are now replaced with a glowing bead of embers. I agree with a natural patina. The time spent fiddling with patina's could be time in the trees for this old dog.
