How do you feel about 1095 taken to that same hardness (as it seems many commercial blades like Beckers/Ontario/Esse)? Do you just prefer a steel with a higher hrc and a little less toughness?
I don't think those companies should change and I know this pisses people off but 1095 isn't super tough.
Those companies under harden and over temper that steel and would probably have MORE toughness with simlair edge holding in a lower carbon steel in the .60-.80 range like 5160, 8670, 15n70, 1060, 1070, 1075, 1077, 1080, 1084, 80crv2.
You won't see a good sword or axes in 1095 for a reason.
The extra carbon makes the steel less malleable and flexible. Even with the extra tempering compared to a lower carbon steel at similar hardness.
People really like 1095 though, and those companies can do a mass production "in house" heat treatment and the wear on tooling and abrasive cost is lower then even if they changed to 52100 with the volume they produce at.
It sells, people like it, people know it, why change.
I personally have no interest.
Back to more durable steels,
There are also more alloyed, low carbon steels that can make some of the most durable almost unbreakable knives and tools
INFI, 1V, A8MOD
Personally I don't care for ultimate toughness in a small blade. It comprimises the edge rentention, I find a high performance cutting edge just plain blunts and rolls too fast with acutual cutting.
I strongly feel a knife is made to cut.
Alot of people argue they use there knives as "tools" which usually implies they scrap, twist, torque, pry, and chisel with there edges and blades which means they need that toughness to prevent the edge and blade from flat out breaking. Either way the edge goes blunt on any knife from those types of use and should be considered "abuse"
Since I don't usually pry, chisel, scrap twist, and torque why should I be punished with a knife that goes dull fast?
Just comes down to preference, use, experience.
There are a number steels that have the benefit of a longer cutting edge that's still durable but the cost and time to sharpening
Increases.
3v, cruwear, 4v, V4E, PD1, Vascowear, spectrumwear, etc
