- Jun 3, 2019
Got it. Im sure it will be great!
Here's a link to a place that seems to be a good source for building a Wa handle:I would love to learn more about how to make wa handles, especially if it is easier to do than what I am planning. I had no idea there was private messaging, I just registered a few weeks ago.
That handle looks nice. I will attempt something much more basic using two pieces of wood and no spacers.
I would round the spine and choil after the HT and leave some extra meat on for post HT clean up, also some on the tip for grinding to leave room for mistakes if grinding too hot or fast. Doing a very small step down on tang is a nice touch for easier and cleanet fit on WA handle. There is a nice video on YouTube by simple little life for this step.
Thank you for that link, he makes it look easy. I have been wondering about this construction method. Do I need a drill bit that can drill to the full depth of the tang? My blade is only about 2mm thick and the drill bits I have close to that size are really short. I have a hard time envisioning how a jig saw blade would let me make the slot deeper. I have been wondering whether it would be possible to adapt an oscillating tool for this purpose, though.Here's a link to a place that seems to be a good source for building a Wa handle:
https://coltonhandcrafted.com/2018/11/11/wa-handle-dimensions-and-shaping/
If you continue to battle the curvature in the blade .... you might want to review JT's comments on using a carbide peen to straighten blades - it seems like the technique works very well....The blade came out of the oven looking like a wet noodle with a severe S-curve. Plate quenching straightened it a good bit, but it still has a pretty severe bend. The 0.04" blade was even worse. I did the dry ice + alcohol treatment, that was fun. They are both clamped to a piece of angle iron in the tempering oven. I'm hoping they'll come out a little bit straighter.
You do really need a bit to drill full lenght of tang. On the one Wa handle I made (plan more) I drilled larger hole than the thickness of tang, then filled with epoxy. To make it look good I used a 3/16" brass bolster in front to hide the larger hole in wood.Do I need a drill bit that can drill to the full depth of the tang?
Murray Carter has a youtube video where he shows how to do it. I don't have a carbide peen, but I might need one. The first temper cycle did very little if any straightening...If you continue to battle the curvature in the blade .... you might want to review JT's comments on using a carbide peen to straighten blades - it seems like the technique works very well....
I have seen pictures of knives with a thin brass or copper bolster. How do you attach that? Is epoxy strong enough for the end grain joint, or do you have to pin it some kind of way?You do really need a bit to drill full lenght of tang. On the one Wa handle I made (plan more) I drilled larger hole than the thickness of tang, then filled with epoxy. To make it look good I used a 3/16" brass bolster in front to hide the larger hole in wood.
A jig saw blade wouldn't make hole deeper than the drill bit.
Actually you do not. This is one of the tidbits I learned from Carter Hopkins.......You do really need a bit to drill full lenght of tang.
