Ban, do you take off the scales to finish the knife then reattach them?
What is your method?
Perhaps you could post pics of the process?
Thanks ! It looks great.
That thing looks SCARY sharp. Excellent job. Is that your ZTMS?![]()
1) The handle scales are removed by drilling out and punching out the flared rivets.
2) The new profile of the knife blade and/or handle is ground out depending on request.
3) The flats of the blade is sanded down progressively from 60, 120, 300, and 400 grit until all the dimples are removed.
Note: When the flats are sanded down they eat into the primary bevel of the knife. Most of the time about 1/8-1/4 of the primary bevel is converted to flats during this process.
4) The primary bevels are reground progressively from 60, 120, 300, and 400 grit.
5) The entire knife is now given a hand rubbed satin finish finish from 80, 150, 320, then 600 grit.
6) The entire spine from the tip to butt of the knife is polished out and given a radius/bevel on all the sharp edges.
7) The handle scales are reattached and the handle slabs are now ground down and re contoured if the handles were modified.
Wow!
That's awesome! Thanks for posting your process. I might try "satin'ing" up my S6.
