Hi and welcome.
Like Langchop said, people will tell you to get known steel- it does take out the guess work for the heat treat. I agree with both opinions. BUT the best argument for using it is...You already have it at the house, why not give it a try...no waiting for a shipment, explaining to the wife why you have to spend money to make something you won't sell. I believe in using what you have, especially to try new ideas out on. You will still have to shape, grind and heat treat the blade, even if you buy a known steel like O1. I always feel like I am not wasting good steel when I do a blade out of this stuff and really goof up- it was usually either free or cost less than a dollar a blank. Plenty of people have first knives made out of saw or mower blade steel. "$50 Knife Shop" and "Blade's Guide to Making Knives" both have Wayne Goddard making knives out of an old mower blade with a home-made grinder and some files- his view for the articles was to make a knife with what you had handy- the best equipment and materials mean nothing without skill.
Is it a circular saw or band saw or what? Thickness and diameter or blade width/length? width/length? Cut a few small pieces off, notch them and heat them to non magnetic (one at a time for the next step). Quench the first one, see if a file slides off it or bites (sliding is good-means its hard) and see if it snaps off in a vice at the notch. If it does, then the steel hardens. Get your oven up to 400 and temper the next one you quench for an hour-slight bite with file, straw color to the steel. Try different temperatures in the oven, maybe to 450 to temper the other pieces after you quench them. Take notes on the temps. Depending on the size of the saw blade, you can get quite a few knives out of it. A Dremel with heavy duty cut off gimmicks works great for getting the most blade out of a circular saw if you don't have access to a plasma cutter or torch.
Enjoy the experience and get known steel when you want. Of course, if you figure out the right heat treat temp, you have at least 3 blanks (or a lot more if you do partial tang or have a big saw blade) of known tempering steel, even if you can't name the actual type of steel.
