- Dec 13, 2005
I was watching a video earlier today of Ray Mears in Sweden, loaded with lots of good info and really pleasant too. But he showed a really cool, simple, and useful trick. This may be in the 'common knowledge' realm for lots of folks here. He mentioned that it was common practice during WWII.
He just took a piece of wood, about 12" in diameter and a couple of feet tall. Round, with a flat top and bottom. He used a chainsaw (but anything would do) to make two perpendicular cuts downward onto the wood while it was standing up, dividing it into 4 tall and ~equal pieces. I believe he left them connected at the base, so they weren't through cuts.
Then he slid bits of tinder (leaves and twigs) into the gaps between the wood. After getting those to burn well, eventually the inside 'panels' of exposed wood were burning, putting off tons of heat upwards. This made a perfect and completely controllable stove! Totally simple, and effective. The bottom also stays cool so it would work in the snow. And if you do split the wood all the way down, you can just shove each piece into the ground to fix them in the right positions.
Wish I had a pic or vid to better explain things, I'll try to get out and snap one soon.
Anyone else already doing this trick?
