- Aug 12, 2002
hahah Bruce, good for you. Can't wait to see it.
TO Dan, as Bruce seemed to ahve said, or led to here, think you'd heat treat it same as a blade. Has to be hard, but can't be brittle(reason you see bimetal hacksaw blades that have hardened teeth wlded onto a flexible steel frame). I think if you are doing it yourself, best HT would be a clay coat on spine/center that isn't going to be a bevel or saw(if that makes sense. Hard to describe without knowing actual blade design and such) and then a regular temper. Or if you feel like being more complicated, you might do a low temp temper for whole thing, so that saw teeth are still pretty hard, then use torch to do a selective temper on actual edge to soften it up a little more and remove some brittleness. Again, kinda hard to say without knowing actual knife.
My .02
My .02
