Infi-del
- Apr 6, 2009
I watch the video and I think people are comparing apples and oranges here.
The sawvivor type saw is is not made for speed cutting, its a saw designed to be used with only the weight of the saw (Any more pressure and you won't get a straight cut) and its not to jerked back and forth like in the video, the movement should be more slow and fluid. With this type of saw you should be able to saw for several hours with out getting tired.
The folding saw type I believe is made more for convenience and quick work.
Kind of like you saw the branch or 3, put it in you pocket and go about your business.
Not prolonged cutting.
If I were to spent the night camping I would go for the folding saw.
If I were to spent 10 nights camping the same spot I'd take the sawvivor (or the type of saw) and cut the fire wood the first day.
The folding saws require no more force than the sawvivor. They generally have beefier blades with more modern tooth designs so they simply don't require the bulky frame. Not requiring more force and cutting faster means you're saving calories... very important if your food sources are limited. And faster cuts simply mean less time spent on fire and shelter building and more time available for water and food procurement, or rest. My Silky Big Boy has a 14.5 inch blade. I cannot imagine ever needing to take on a log larger than 12" in diameter in any sitaution. Unless I were building a log cabin... in which case I'm gonna have real tools with me.
