Scale Removal Question???
BTW, DennisM DennisM , if that red loktite‘d screw needs to come out (e.g., you want to reuse the spacer with different screws), just put the spacer with screw for a few sec over heat, for example a gas stove or similar. Don’t put too much pressure on the spacer with pliers or similar.
Good question.
DennisM DennisM - after you thread the screw about two thirds out of the barrel/spacer. Use your thumb and push that screw until it is seated in the scale again. Then unscrew it the rest of the way. This the best way I have found to get the barrel out without galling it.
