- Jul 30, 2006
anyone ever have scales installed on Skeleton Wardens
Thanks Because i asked Busse to do it in there custom shop,sent a Email to Garth if the could have snakeskin scale installed on all the Muddy Wardens i got last weekend he replied to my email and said it could not be done.
The reason for this, and what will make it hard for anyone to do it, is that they have 2 large holes in them. This gives them the skelitized look. There is no place to properly install handles fastners. This meanes either the holes need to be filled and drilled prior to fitting handles or the handles need to be custom machined and fitted to the holes. Either way its alot of work.
You could try Justin Gingrich of Ranger Knives, he's done a few different Busse's for me in the past and is very reasonable.
This was my suggestion too. I'm about to send Justin an old Blackjack Becker Brute and let him do some scale magic on it.
OR you could just strip the coating, and just use a heavy duty epoxy!
(you might want to rough up the handle first with a high grit sandpaper first)
It might not last forever, but it will probably outlast you!
Seriously, this is a pretty easy at home project. I recommend just doing it yourself!
If it was a bigger knife, you'd probably need pins, but I just don't see that much torque being put on the handle of the GWs.
Actually....This is exactly what I have planned. In fact, I stripped one of mine mine just today, and it seems plenty rough enough for a good bond.
Randucci stripped one right after they were first released, don't know what he did with it after that.
