- Dec 21, 2006
I have made my first scandi grind blade out of the latest 1/8" W2 batch. I believe I have gotten the total angle too low....right at 13 degrees. 6.5 per side. Wasn't entirely trying to go that low. Maybe 15, but moving material from the bevels pushed my grind line up further than I would have liked, lowering the overall angle. What is your opinion on my knife's angle of 13 degrees total angle? I know the steel and heat treat plays a decent factor in how low you can get. W2, kiln heat treated. 1450F for 15 minutes into room temp P50. Tempered 360F 1 hour. 400f two hours. 430F two hours. Impressed with how the W2 came out of the quench.
I am thinking that 13 degrees, even with awesome steel and heat treat, is too low. Microbevel might be the best thing here. I'm not too sure about micro bevels, I'll have to read up on them.
Thank you for your thoughts! (It's not done! Excuse the finish. It's only at 400 right now, and I'd like to go to at least 1800 on the bevels, as they form the edge, and I want a fine edge. I may be doing too much in that alone....IDK?)
Stu
Stu
