- Mar 8, 2008
I'm not convinced that what you describe is true for this type of knife (or maybe I'm misunderstanding you). Without changing the geometry, I can only see cutting power increasing with added width under two conditions: (1) if you are chopping with the blade or (2) if the blade is bending when you are trying to apply force with the edge. The nessmuk wasn't designed for chopping, so I don't see the first being an issue. Nessmuks have a narrow 'neck,' so adding width toward the tip wouldn't increase strength, anyway, so the second condition doesn't seem likely, either.
- Chris
Never said it increases the strength--rather that it makes the mass of the blade more efficient. The degree to which increased width increases cutting power is most noticeable on large chopping blades, but that's because the effect is so massively magnified due to factors of scale. If you were, for instance, to take a boning knife and a butchers' knife of equal length, grind (lets say a short hollow saber grind so we keep things as similar as possible), and thickness, and try cutting a melon with the very tip of it, you'll find you probably have an easier time with the butchers knife.
There are some additional factors at play having to do with leverage and the point of balance as well. Applying downward pressure at or behind the fulcrum caused by the point of balance will be the easiest. Of course, once you make contact with the cutting medium you establish a new fulcrum with the point of balance now acting as a marker of the shift of the scale, so to speak. Initiating the cut right at that point, stacking the fulcrums, is going to be the easiest to deal with.
Note that the point of balance is not the sweet spot. The sweet spot is the center of percussion, and the place where chopping will be most efficient. The forces at play during chopping are different than those during slicing.
Who knows--I may be way off the mark here--but that's my experience.
