Cliff Stamp
BANNED
- Oct 5, 1998
laurens said:.The standard argument I hear for the scandi grind is that the shoulder of the secondry bevel causes wedging when working with wood.
Many people focus on the shoulder but this isn't the actual problem. The knife will binds around the flats, machetes are the same way. This is why hardwood axes have primary hollows and are not left flat above the edge. Japanese also run hollow grinds on wood working chisels and most knives for the same reasons.
“to complete the process I run the blade very lightly down the finest ceramic sharpening rod to give the edge more bite” it seems he only does this once at least that the impression the book gives.
Ok, I had a different impression. If he is getting more bite that way though it is because he isn't sharpening properly at the full angle and not actually forming the edge but just doing a coarse shaping. This is one of the problems of sharpening such a wide bevel.
...matching a micro bevel that less than millimeter or so really requires concentration.
You need to sharpen at your own natural angle and not some preset one. I would find it very difficult to try to hold 17 degrees for example as I never sharpen anything at that angle. If you are having problems you can hold the knife fixed and just use the stone as a file. This allows you to directly see the edge as it is abraded. Hold the knife in your left hand with the edge pointing to the left and just work the stone along it with the edge outlined with a marker. You will immediately see the color being removed and adjust accordingly.
The thing which most people don't realize is that you don't actually need any precision until the edges meet. You can shape the edge as sloppy as you want. Just take a coarse stone and shape the bevel until it meets at an apex and can catch on your fingernail. Once this happens then elevate the knife on the stone and give it a few light passes to set the very edge with a tiny microbevel about 0.1 mm wide. Because the micro-bevel is so tiny you can make quite a jump in stone grits. You also don't need a lot of precision because of the effect of the relief grind.
Using this general method you can easily get knives sharp enough for any brush work, moving to the ultra sharp shaving above the skin takes a little more skill and is worth the time to practice, but it isn't something I would demand from a beginner. It would be like demanding someone start off fire making by using friction methods in a sleet storm. This isn't a goal you would try to have right from the start but just something you work up to gradually as you master the basics.
-Cliff
